Marshall SC20H: not so good sound...please help!
Discussion in 'Marshall Amps' started by panoma, May 14, 2021.
  1. panoma
    panoma Member
    Feb 11, 2020
    20
    36
    Hi,
    hope some help from the experts:
    New SC20H arrived two weeks ago; my signal chain is very simple, Gibson LP Standard 60s 2019 bridge HB straight into the high sensitivity input of the SC20H paired with its SC212 cabinet, Preamp at noon, Master at 3; I am looking for 'solid' rock sound ala AC/DC but the sound has always a very strong high frequencies boost, too strong and I cannot reduce this with EQ knobs: Presence, Treble all the way down to zero (!) but no significant result; moreover some scratchy noise (with fading behaviour) is randomly heard especially on bi-chords on lower strings...
    As a test I have plugged the guitar directly to the RETURN input with effect-loop ON and the post-master sound of the power section is crystal clear, well balanced with no issues at all.
    I am wondering if I have some problem with the pre-amp valves........
    I am really disappointed :shrug: also because I have a CODE100H and I can get an almost decent JCM800 sound.....so there must be some problem..........
    thank you for any suggestion (before calling thomann customer service........)
    Mitchell Pearrow, scozz and tce63 like this.
  2. pedecamp
    16,831
    15,805
    Take a known good 12AX7 and try it in each slot until you find the bad tube, thats all you gotta do! Congrats on the new amp! :yesway:
  3. marshallmellowed
    Jun 26, 2009
    4,583
    6,707
    Could be that it's just brighter than you're used to, or you're using very bright speakers (V30's...). Beyond turning the Presence and Treble down, you could try an EQ in the loop, or try some darker sounding preamp tubes (JJ...).
  4. panoma
    panoma Member
    Feb 11, 2020
    20
    36
    The cabinet I am using is the SC212 with 2x 12" Celestion V-Type but I am not expecting such a super bright tone and also the scratchy sound is annoying
    Unfortunately I have not a good 12AX7 to swap the preamp slots; is there a quick manual way to check if the pre valves are properly set in place?
    tce63 likes this.
  5. Kinkless Tetrode
    Aug 17, 2017
    1,518
    2,147
    Brand new amp? You could take it back for another if its defective.
    800's are bright, but I don't think it should unbearable with the treble and presence at zero.
    Brand new speakers? They might need break in. The 800s were voiced for the G12-65.
  6. Kinkless Tetrode
    Aug 17, 2017
    1,518
    2,147
    Just wait for them cool and pull them straight up and out and then push them straight down the same way. The V1 tube probably has a metal sleeve over it. You push and twist the metal sleeve to remove it or to put back on. You could tap lightly on the tube base with a pencil to test if the tube is microphonic. It will be like tapping on live pickup if that is the case. But if the tube is just plain bad that might not show anything. You really need a spare 12AX7 to find out if it's a defective preamp tube.
  7. Dogs of Doom
    24,349
    29,515
    Just a note...
    If playing tube amp's, you must have extra tubes hanging around. They are a necessary part of owning a tube amp.
    If something goes bad, you can plop one in, to get you through the show.
    It very well could be a pre-amp tube. I'd call Thomann anyway. If it's a tube, they should be glad to solve it that way, rather than going through all the hassle of return of merchandise.
  8. hpharley90
    hpharley90 Member
    Jul 10, 2017
    84
    75
    CT
    My suggestion is to call Thomann. its brand new call them...
  9. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    4,138
    4,263
    detroit rock city
    volume at 3 isnt that great try 7
  10. panoma
    panoma Member
    Feb 11, 2020
    20
    36
    master at 7 is impossible in my apartment :)
    thanks everybody for all the suggestions, tomorrow I will inspect the valves but I do not want to invalid the warranty: the amp is brand new so I will eventually call Thomann for service and see what they will tell me
    I will keep you posted
    Any other idea is well appreciated
    a big thank you from Italy!
  11. tce63
    Aug 6, 2018
    2,040
    5,642
    Sweden
    I have a Marshall 2061CX with V30:S and that sounds great with the SC20H, I have master at 8 and the pre amp at 4.
    I use a Weber Mini Mass 50 attuenator at home.
    Fantastic amp, Call Thomann, they have great support :applause:
    And HNAD
    Cheers :cheers:
  12. ken361
    Aug 30, 2009
    4,138
    4,263
    detroit rock city
    change the v1 valve and try it then on to 2 and 3rd valve. If you dont have any try moving them around can't hurt anything.
    Mitchell Pearrow and CroTone like this.
  13. CroTone
    CroTone Active Member
    Nov 24, 2019
    92
    167
    I had my JCM 800 Studio series head coming with a defective V1 preamp tube right out of the box.
    In the beginning, I thought that maybe some of the tubes got loose during the transport but it wasn't that. The culprit tube was just not working after I did some testing later on.
    Swapped V1 with another one, the amp was working just perfectly! Enjoy SC20 and don't give up...they are awesome little beasts! And I also use it with V30's...and play with a telecaster...not too trebly at all if you set your settings appropriately.
  14. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    1,773
    1,882
    Call the place you got it from and see if they will send a tube or 2 to see what is wrong. This will at least get a paper trail going and they will know it’s not right. If it does not work good with a new tube then you can send it back. If you can’t get a good sound out of it at low volume, it might not be a good fit for you.
  15. ken361
    Aug 30, 2009
    4,138
    4,263
    detroit rock city
    I have not played low in awhile but it sounded pretty good today with my new Les Paul and the Hendrix curly cable its probably a bad tube lets hope
  16. panoma
    panoma Member
    Feb 11, 2020
    20
    36
    I have taken the preamp valves out and reinserted them without swap; nothing changed. I might try the swap but a question: are all three the same valve model 12AX7/ECC83 ? Shall I swap them any combination I like? Why only the first from right has a shield cover? Sorry for the questions but I am pretty newbie in amp internals....and I do not want to void the warranty....
    Another question regarding the FX loop: is the Master volume BEFORE the SEND output ? Guitar plugged directly in the RETURN input does not seems to be modified in volume from Master knob...
    thank you....
  17. marshallmellowed
    Jun 26, 2009
    4,583
    6,707
    The 1st tube is the 1st gain stage, so any noise picked up by that tube will be further amplified by the following gain stages, hence the tube is better shielded (metal cover). You can swap any of the 3 preamp tubes with the others. The 3rd tube is the phase inverter tube, the other 2 are preamp tubes. Yes, the master volume is located ahead of the FX loop.
    scozz, Mitchell Pearrow and ken361 like this.
  18. Sapient
    Sapient   Silver Supporting Member Platinum Supporting Member
    Mar 14, 2020
    2,892
    5,639
    Yes
    With the amp on. Tap the tubes lightly with a pencil. Do you hear a microphonic sort of sound? Or any odd sound over a different one?
    Not saying this is 100%, but it's sure worth a try.
  19. Mystic38
    Mystic38 Well-Known Member
    Oct 19, 2015
    382
    447
    IT may be faulty (see all tube comments above) but..
    AC/DC tones are more associated with Plexi style amps than the JCM800.. which is a pretty bright amp.
    turning the master up may help with fullness, as would an EQ before the amp, in the loop or both, but if your goal is THAT sound, then I think you may be better off with a different amp.
  20. FleshOnGear
    FleshOnGear Well-Known Member
    May 2, 2017
    335
    499
    I have never owned a JCM800, so I’m no expert. But, maybe try plugging into the Low Sensitivity input and cranking the preamp. This will dial out the bright cap on the preamp control, and maybe give you a fuller sound, although with less gain. It’s worth a try.
    Based on what I’ve read so far, if the amp or tubes isn’t faulty, you might be better off with an SV20 with a passive volume box in the effects loop.
