Marshall Origin Series Amplifiers
Discussion in 'Marshall Amps' started by Micky, Jan 25, 2018.
  1. Mitchell Pearrow
    15,290
    30,387
    Hell yes :band:
    :cheers::dude:
    tce63 likes this.
  2. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    16,792
    20,315
    Taintville
    Thats right!
  3. Tim D Stinnett
    Tim D Stinnett New Member
    Apr 4, 2020
    My manual says to plug an 8 ohm cab in socket #3. But on the back of the amp it say #2 is 8 ohm and #3 is for 2x16 ohm?
  4. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    1,922
    2,703
    Woah ,Woah woah back up, have'nt followed this thread in a while.What am I lookin at here? That looks killer.
  5. Rooster-p
    Rooster-p Member
    Jun 2, 2019
    70
    82
    I have the 20c and it came with the defective speaker Jack but I got the fix off this forum, I believe it was this forum, and I fixed mine myself. I'm no technician but I'm quite mechanically inclined, anyway it's nothing but a jumper wire that you solder right back at the Jacks and it's good as new. You have to pull the chassis but it's fairly simple.
  6. Rooster-p
    Rooster-p Member
    Jun 2, 2019
    70
    82
    I've been playing my origin 20 through a keeley germanium red dirt coming out of a love pedal amp eleven and it freaking rips. Even just playing through the germanium red dirt it's got a hell of a growl. Highly recommend. I have a seriously modded Ibanez 808s and I like the keeley a lot more. It's got this grainy growl that's hard to explain but man it's nasty. I'm running mullard's in my origin and I've done some tube rolling and they seem to work the best if you want that Marshall growl. I've tried tungsol, JJ'S, GT'S, winged C, and mullard's definitely take it. Definitely a sovtek12ax7Lps in the phase inverter position but I'm using the genalex b759 gold lion version and it definitely makes a difference. Tungsol in V1 and a g12h 55 hz celestion greenback instead of the pewny 10" it came with. Definitely the baddest origin 20c on the block.
  7. Jason Fieldhouseespk
    Jason Fieldhouseespk Well-Known Member
    Apr 21, 2018
    487
    656
    This jumper wire? ;-)
    I had this done at Marshall UK, I rang them 4 weeks after sending back to the retailer, to see if they'd got it yet. They hadn't, do they rang said retailer and organised with them, and I got it back before the end of that week... pays to be cheeky enough to call em. :-D
    steveb63, tce63 and Mitchell Pearrow like this.
  8. Rooster-p
    Rooster-p Member
    Jun 2, 2019
    70
    82
    That's the culprit. I just didn't feel like waiting when it was such an easy fix and I'm not worried about the warranty. I can usually fix it myself. Haven't had a problem with it since.
  9. davestp1
    davestp1 Member
    May 17, 2010
    42
    7
    Berwick NS Canada
    I've got an 8 ohm celestion gold. Will it be no problem to hook it into the number 2 speaker out (The 8 ohm one) I assume it will be just asking before I hook it up and get vapourized....
  10. Sirroderick
    Sirroderick New Member
    Aug 1, 2019
    5
    I just bought a 20H and am hooking up a 2x12 8 ohm cab. I plugged it into either of the two 8 ohm jacks and it sounds awful and dull and weak. I plug into the 16 ohm and it roars like I would expect. I also believe my amp has the jack issue still...but I thought the issue mainly contends with trying to plug in two 16 ohm cabs at the same time and only one would work? Why doesn't it work good with just one 8 ohms cab? It sounds great in the 16 ohm jack but this can't be healthy on the the 16 ohm tap on the transformer...
    fitz288 likes this.
  11. fitz288
    Apr 7, 2020
    3,640
    8,958
    rahndahbaht dah 'Burgh
    Do the jacks have the sticker that looks like this?
    This is how it would look if you got one with the jack fix.
    I got mine used, so I don't know if this was factory or service center fixed.
    If not, the "fix" is a relatively easy fix if you can use a soldering iron. (see post #647)
    And, :welcome: to the forum.
    Edgar Frog and Mitchell Pearrow like this.
  12. Sirroderick
    Aug 1, 2019
    5
    I'm not with the amp right now...but am quite certain that I did not see this sticker. Nor do I know the build date. I'm assuming that Marshall would have remedied this when first discovered and am guessing that newer ones would not have a sticker on them? Do they then have different graphics printed on them instead of a sticker? Any way...even if has not been fixed, it should still run a single 8 ohm cabinet...and it does run it but with a VERY disappointing tone. I will check tonight on the sticker...or for that matter I will plug two patch cables into each 8 ohm jack and test for continuity between tips and sleeves.
    fitz288 and Mitchell Pearrow like this.
  13. Sirroderick
    Aug 1, 2019
    5
    So....last night I rechecked and redid my tests and here's the scoop:
    1. My 20H is a newer one with problem eliminated. Manual (still with the unit from original purchaser) states that to use one 8 ohm cab to plug into jack #3. (furthest right) When I do this, output is weak, whimpy and if I were demoing this in a store would have steered VERY clear of.
    2. Unlike I remember from original testing the night before, Jack#2 sounded great and was what I would have expected...
    3. Jack #1 (16 ohm) sounds great as well and was using it the night before as a comparison to the others in troubleshooting. It sounds very comparable to Jack#2 which was a great relief now knowing that I can comfortably use Jack#2 now with the correct impedance.
    4. So...what's up with Jack#1???? I am suspecting that the Jack contacts on Jack#2, when not in use, are not connecting/closing well and are screwing up Jack#3 reliability... anyway...I'm just using 1 cab anyway so this will work okay...
    Thanks all for your input and help!!
    Sirroderick
  14. Mitchell Pearrow
    15,290
    30,387
    Welcome to the forum glad you got a handle on it, have you been able to run 2 16 ohm cabs through the 2 - 8 ohm jacks ??
    Cheers
    fitz288 likes this.
  15. fitz288
    Apr 7, 2020
    3,640
    8,958
    The manual is not correct (they fixed the jack - not the manual).
    I have my 8 ohm cab (2 ~ 16ohm Vintage 30s parallel wired) in jack#2.
    I'm not sure where I read this, (might have been here) but for a single 8 ohm load you should use jack#2
    Only use Jack #3 when doing 2x16 ohm cabs in jacks#2&3.
    The sticker in my pic above sort of shows this.
    SO:
    Jack#1 is 16 ohm
    Jack#2 is 8 ohm
    Jacks#2&3 are internal parallel wired after fix to 2x16 ohm to the 8 ohm OT tap.
