Marshall lead 30 burnt opamp issue
Discussion in 'The Workbench' started by sandro70, Apr 16, 2021.
Keep original MC1458 or go for modern opamp?
  1. Yes, keep the old buddy!
    100.0%
  2. Are you kidding? Waste that '76 garbage chip!
    0 vote(s)
    0.0%
  3. Choose another hobby, guitars are too noisy and neighborhood unhappy...
    0 vote(s)
    0.0%
  1. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
    Hi,
    I have a Marshall lead 30 burnt opamp issue, some months ago I swapped the MC1458 opamp to RC4558 and it sounded good, IMHO better; then I burnt it playing an overdrive, surely a strong input signal or I guess so. Opamp tester blinked red led all the line.
    Substituted with LM308 playing clean and good. But again I inserted a Boss FDR (a fender twin-reverb emulator) and craaack, craaaack (loud noise of dirty pots)...the end, no sound at all. Speaker working, checked with a battery.
    I assume it's a voltage issue, I'd like to use a RC4558 again but not sure which components check first to avoid overLOAD.
    Bad resistor, diodes, capacitors at +V opamp input? Bad negative feedback?
    Not an expert so...Any clue please?
    thanks
  2. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
  3. Matthews Guitars
    3,757
    5,661
    Go back to the stock MC1558 part and strap 14 volt zener diodes across the inputs to ground as a device protection measure.
    Put a DIP socket on the board so you can swap the part without having to solder it AGAIN.
  4. thetragichero
    Jun 6, 2010
    3,230
    1,171
    flo rida
    are you sure you used an lm308 in place of a dual op amp? i definitely would expect the chip with a different pinout to fry (your amp is putting v+ on pin 8 while the lm308 expects v+ on pin 7; pin 8 is one end of the compensation capacitor)
    the zener suggestion is a good one
    Pete Farrington and sandro70 like this.
  5. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
    Thank you guys,
    ok back to MC1458 with socket (already soldered) and zener 14V (just 12V in stock, maybe fit well the same?) ...for inputs you mean jack IN or/and op-amp #3 V+ input?
    PLease check picture, A or B?
    Not sure about fried LM*** code, I'll check tonight.
    ciao
  6. thetragichero
    Jun 6, 2010
    3,230
    1,171
    flo rida
  7. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
    Good! Appreciated!
    U right not a LM308 but well fried LM1458!
  8. thetragichero
    Jun 6, 2010
    3,230
    1,171
    flo rida
    over voltage protection is my guess
    sandro70 likes this.
  9. Matthews Guitars
    3,757
    5,661
    Even better, strap 14 volt zener diodes to ground thru 47K resistors in series. That should make the zener clamping effect much less harsh sounding. But if you're clamping via the zeners, your input signal is too hot anyway. Lower it so the clamp doesn't trigger.
    sandro70 and Pete Farrington like this.
  10. mickeydg5
    mickeydg5 Well-Known Member
    26,080
    13,113
    united States of America
    A Boss FDR is nominal output -20dBu.
    What are your voltages on pins 4 and 8 of the opamp?
  11. Pete Farrington
    Pete Farrington Active Member
    Jan 18, 2021
    133
    125
    10k input impedance on a guitar amp - what nonsense is that?!
  12. thetragichero
    Jun 6, 2010
    3,230
    1,171
    flo rida
    isn't op amp input impedance pretty much infinite?
  13. Pete Farrington
    Jan 18, 2021
    133
    125
    For the device itself, yes, basically it’s defined by the circuit, eg R2 (10k) in this case.
  14. thetragichero
    Jun 6, 2010
    3,230
    1,171
    flo rida
    shouldn't it be r1 + r2 in this case?
    Pete Farrington likes this.
  15. Pete Farrington
    Jan 18, 2021
    133
    125
    Oops, yes, I saw the bypass cap C1 and misread it as being a full bypass :rolleyes:
    Whereas it is very, very partial.
  16. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,838
    2,183
    Södertälje, Sweden
    1458 or possibly 4558 are the only ones that belong in there... if you want better protection, antiparrallell diodes across the inputs, like the old musicman amps, Is probably the best you can do on an opamp input.
    J
    sandro70 and thetragichero like this.
  17. johan.b
    Feb 21, 2015
    1,838
    2,183
    Södertälje, Sweden
  18. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
    MC1458 in/out values 1458 input.png
    Local store got only 13V in stock.
    4558 sound better in my opinion;
    sounds good!
  19. sandro70
    sandro70 New Member
    Jan 16, 2021
    21
    2
    Italy
    I'm on the right path?
      File size:
      100.4 KB
      4
  20. mickeydg5
    26,080
    13,113
    No, I do not require a datasheet. I pull one of those up myself.
    What I want to see and what you need to find out is part of troubleshooting, getting voltage readings from the power supply to the opamp.
    thetragichero likes this.
