Marshall lead 15 no output
Discussion in 'The Workbench' started by Shardik, Jul 14, 2020.
  1. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    I'm fixing a marshall lead 15 for a friend. It had a burned up resistor(r32) that I replaced but I couldn't find a schematic so I guess I winged it and put in a 10k 1/4 resistor there. Now it powers up but I have no output out of the speaker outs.... it has a headphone jack and a line out on the front panel I get output out of them but not the speaker outs. Any help would be appreciated.
  2. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,958
    4,816
    Lakeland, TN
    What color bands did the burnt resistor have? You should be able to determine what value it was based on the color bands.
  3. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    It was completely burned off the resistor
  4. Micky
    Apr 29, 2010
    20,975
    17,560
    Vermont
    What model number? Is it all SS?
  5. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    2,701
    3,682
    At Home
  6. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    It's a g15ms
  7. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    Yes it's all ss
  8. Ken Underwood
    Oct 16, 2013
    615
    1,477
    Annesley North Notts UK
    Never try to repair an amp if you dont know the basics and to try to do it for someone else is totally crazy.
    You are doing your mate no favours
  9. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    I'm trying to learn more about amp repair this is an amp that a friend had lying around that he said I could try to fix. I'm just here for advice on where to be looking and gain some knowledge.
  10. Matthews Guitars
    2,219
    3,057
    A burned resistor always mean that it was connected to something that drew too much current. Without knowing the circuit or seeing the schematic I would be unable to make a more positive diagnosis but I'm going to BET that the burned resistor is just a symptom of destroyed output transistors.
    So, new resistors of the right value isn't going to fix it. Replacing the damaged transistors and the current limiting resistors will probably fix the amp.
    You can start there.
    You may want to reference the schematics for a Lead 12 or a Lead 20 as a guide. They won't be exact but the Lead 12, 15, and 20 all share some basic similarities.
  11. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    Thank you
  12. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    So I'm looking at the transistors they say jcr4558DD and below that it has d128d is that a production code? I can find jcr4558dds listed but they all have different numbers on the bottom. Just want to make sure I order the right thing.
  13. jmp45
    May 5, 2016
    2,701
    3,682
    At Home
  14. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    It only has three of those transistors I might just replace all three and see if that does it
  15. Christianw123
    Christianw123 New Member
    Saturday
    Hi, I have exactly same problem on the same same amp which I picked up at charity shop today for peanuts. Wondering if a simple R32 resistor replacement was Enough to fix you problem? Or was there other issues? I have power but zero output and burned out R32.
  16. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    I am waiting on my order of the output transistors, I'm gonna replace all three but I'm gonna do it one at a time. I'll let you know what I find out.
    Christianw123 likes this.
  17. Shardik
    Shardik New Member
    Jul 12, 2020
    18
    2
    So I have replaced all three of the diodes.... and nothing for the speakers outputs. And I realized the reverb does not work either. I dont know if it worked before or not to be honest. The headphone out and the line out work. If I run the line out to a cab it is actually pretty good sounding amp! Any other suggestions?
