Marshall JCM 800 2203 no distorition
Discussion in 'Marshall Amps' started by PeeJay, Oct 15, 2021.
Tags:
  1. PeeJay
    PeeJay New Member
    Oct 15, 2021
    4
    Hey.
    Ive recent got a Marshall JCM 800 2203 from my late father. Its with a Marshall 1960 Vintage cab. Ive only played on combos, so I have not much experience with this one.
    Heres to the problem. No matther how I twist and turn the knobs, HI or LOW, I cant get any distortion out of it. Ive searched some youtube reviews on this amp and it sure got alot of crunch to it. Im guessing it needs some sort or repair. Anyone knows what might be wrong with this amp?
  2. FutureProf88
    FutureProf88 Well-Known Member
    Oct 2, 2012
    2,349
    1,928
    St. Louis metro area
    Have you tried new preamp tubes?
    Mitchell Pearrow and Old Punker like this.
  3. Matthews Guitars
    4,975
    7,459
    Preamp volume to 10. Master to whatever sounds good to you. That should be pretty distorted.
    If not...the first thing to check is the three preamp tubes. Wiggle them in their sockets, be sure they're fully seated, swap them around, test them any way you can or just put in others.
    If it's still too clean sounding, it's time to take it to an amp tech.
  4. DreamerDeceiver
    DreamerDeceiver Well-Known Member
    Jul 9, 2021
    1,283
    2,534
    OZ
  5. PeeJay
    PeeJay New Member
    Oct 15, 2021
    4
    I havent tried anything but the obvious. Preamp on 10, but no its still all clean. I have absolutly no experience with this, but should I take a check anyway at the tubes? Yeah I have a tech, I was just hoping to pinpoint whats wrong with it first. Thanks for answers!
  6. neikeel
    6,440
    5,349
    There are a few things that spring to mind.
    Has it been sitting unused for a while? Is it stock or modded?
    The contacts on the input switching jacks may be dirty so you are not getting the cascade between the two halves of V1. Try spraying deoxit into the jack socket and inserting a jack into them a few dozen times.
    Next replace V1 (first small valve - furthest from the bigger output valves) with a new ECC83/12AX7. If that does not work move down the line replacing each valve in turn with the new one.
    If that does not work it will probably need looking at by someone who knows what they are doing!
  7. PeeJay
    PeeJay New Member
    Oct 15, 2021
    4
    Ive tried to switch some of the tubes, checking if they are in place e.t.c. I cant find anything wrong so Im going to bring it to my tech tomorrow. Thanks for your answers.
  8. Leonard Neemoil
    Leonard Neemoil Well-Known Member
    Jun 21, 2021
    178
    255
    @PeeJay, the first thing I'd check is whether or not it even has 12ax7 tubes in it. Maybe dad replaced them with lower gain tubes...
  9. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,895
    2,779
    Make sure that you try both input jacks. One is significantly louder than the other. If you have the pre-amp up to 8 and are plugged into the High sensitivity jack and don’t have distortion, something is definitely wrong.
  10. Derrick111
    Derrick111 Well-Known Member
    Jun 26, 2020
    327
    382
    Maybe he had it modded or used a different (lower gain) tube in the preamp. Check that all three are 12AX7s. If they are and swapping in known good working ones doesn't fix, then you may need to bring it by a shop. Also be sure you are plugging in the High input, not the Low.
  11. Matthews Guitars
    4,975
    7,459
    How about cracking it open and posting a few clear pics of the insides?
    It might be something as simple as someone changed resistor values to make it a totally clean pedal platform.
  12. Solitary49
    Solitary49 New Member
    Mar 17, 2021
    5
    11
    I had the exact same problem with a 1987X that I bought without playing it first. I know, bad idea, but for the price, it was worth the gamble. I tried everything that others have suggested here and nothing worked. It would get extremely loud, but distortion. Everything looked good inside with no obvious abuse. Long story short, I replaced the power tubes and pre-amp tubes and it roared back to life! A good set of tubes aren’t too expensive and a cost of tech to bias the power tubes (unless you can do it yourself) is worth it.
    Mitchell Pearrow and jamvu like this.
  13. jamvu
    jamvu Member
    May 19, 2009
    74
    64
    Lowell, MA
    Solitary49 is likely right. An old amp sitting around for years could just need some new tubes. That thing should be a tone monster.
    Jamvu
  14. pedecamp
    18,012
    18,160
    Look at the preamp tubes, maybe your dad substituted the 12AX7's with something low gain, report your findings. Tell us what power tubes are in it while youre looking. Also at some point check the bias, it should be around 76mA give or take.
  15. pelican
    pelican Member
    Apr 25, 2021
    43
    22
    most likely the jack
  16. Derrick111
    Jun 26, 2020
    327
    382
    That is another one I forgot about on the MV amps... clean the contacts on the little switched contacts of both input jacks. To do this, I usually cut few thin strips or paper (preferably the thicker stuff like a business card - junk mail has lots of it) about the thickness of a match (so it can fit in the jack contact), and grab it with some needle nose pliers, then get it between the jack switched contacts to slide it out - removing dirt/contaminants. I insert a jack tip till the switch contact opens, then place the paper in there, then remove the jack so the switch closes on the paper and simple slide it out which will clean it great. Bonus if you have an electronics cleaner like you use on your controls (DON"T USE WD-40) or even you could use rubbing alcohol.
  17. Matthews Guitars
    4,975
    7,459
    Tubes don't go bad when just sitting there unused. That's why new old stock tubes are so highly prized!
    The connections may get crusty from rust or corrosion or dirt, but as long as the glass envelope is intact and undamaged,
    the tube itself isn't going to wear out when it's cold and dark.
