Marshall DSL40C clean channel boosted or crunch channel
Discussion in 'Marshall Amps' started by Listogast, Nov 29, 2020.
  1. Listogast
    Listogast Active Member
    Oct 12, 2019
    77
    142
    So I've been playing with my DSL40C and messing around with both the clean and crunch channels. I read from the user manual that they say the clean mode is supposed to be voiced similar to a plexi super lead, while the crunch mode is supposed to be more like a JCM800.
    My question is one voiced better than the other? In terms of less compression, more clarity, that type of stuff. Like would it be a better idea to use the clean channel with a boost pedal for some dirt?
  2. Guitar Rod
    Guitar Rod Well-Known Member
    Feb 6, 2018
    205
    344
    Great White North
    For just straight boosting I like the crunch channel better. The clean is pretty clean, so a boost may just increase volume. For actual distortion/overdrive pedals I prefer the clean channel at 3 o'clock, just starting to break up. Makes the pedal distortion sound more natural.
  3. Listogast
    Oct 12, 2019
    77
    142
    Usually I have mine on the crunch channel with the gain just over 10 o'clock, and then my overdrive pedal to add some extra dirt on top.
    tce63 likes this.
  4. solarburnDSL50
    Aug 8, 2008
    17,083
    12,786
    Wetville
    Try it. I found I liked the green clean boosted but I put the amp gain all the way up or near all the way up. Also volume needs to be high enough for the power section to open up that channels voicing.
    Cranking the amps gain and then boosting it gave me great vintage variations to use and cleaned up easily by rolling back guitar volume. Highly recommend.
  5. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    6,564
    7,743
    Montreal
    Really depends on the musical style you want to be playing.
    Personally I use nothing but Green & Clean. Use the volume at higher numbers and dial in the Gain to where I like it. From that point onward it's my board pedals that dial in what I want in terms of guitars being used and songs being played. The Crunch and Ultra Gain channels do not get used.
    BP
    Guitar Rod and Mitchell Pearrow like this.
  6. Listogast
    Oct 12, 2019
    77
    142
    The other day I tried setting the gain really low and the volume higher. I think it sounded more punchy or something. I also tried cranking the clean gain, and then increasing the volume on my overdrive pedal to sort of boost the amp into some crunch. Sounded nice as well.
  7. Jethro Rocker
    8,987
    11,995
    Whatever sounds best to you. Gotta try it. Personally, the crunch channel boosted but I prefer higher gain.
  8. SteelLucky
    SteelLucky Active Member Silver Supporting Member
    Mar 14, 2016
    142
    143
    For a DSL40C: Put a JJ E823CC in v1.
    https://www.amplifiedparts.com/products/vacuum-tube-ecc823-jj-electronics-dual-triode
    What I found once I did that was that the gain channels get a little bit more tame and you can use more of the gain knob. I normally would set the crunch channel good and crunchy then boost it when needed. (JCM800 is my favorite amp). The E823CC made the lead channels way more usable for me. I lot of guys talk about clipping the C19 cap out but I found that Clean and Lead 1 match up pretty well and Crunch and Lead 2 match up better EQ voice wise for me and then I would actually channel switch the amp too.
  9. Mitchell Pearrow
    12,571
    23,132
    Most of my playing is on the green clean channel, with the Vox Tone Lab, but if I am going to play at gig volume I use red 2, with the MXR10 band eq in front of the amps with the gain at 3-5
    On the green clean channel gain is normally set at 2-3 volume to taste.
    Cheers
    Jethro Rocker and Guitar Rod like this.
  10. SkyMonkey
    2,964
    3,854
    Did the ECC823 make any difference in the gain levels between Classic Clean and Classic Crunch, i.e. less gain on Crunch too?
  11. SteelLucky
    Mar 14, 2016
    142
    143
    Yes IIRC. But not enough to make Crunch a clean channel. I did sell the amp so I do not have it to test for you. But the DSL40C had a ton of gain on tap and still did after the tube swap. I just felt it sounded better to me and gave me a more usable gain knob. I used Crunch and ran that about 7 or 8. Lead 2 gain set to 3 to 4. Stock speaker. T3, M7, B5, P3, R5 were my EQ starting points. My guitars have EMG’s or hot passive pickups.
    SkyMonkey likes this.
