Marshall DSL20H speaker jack confusing
Discussion in 'Marshall Amps' started by heave1, May 13, 2020.
  1. heave1
    heave1 New Member
    May 5, 2018
    12
    This may be a dumb question, but the speaker outlet jacks on the DSL20 head are confusing as to where to plug in your speaker cabinet. The one on the left is labeled 1x16 ohms and is self evident. The 2nd and 3rd jack are confusing. Does the 1x8 ohm speaker cable go in the middle jack and the 2x16 ohm cable into the right jack? There is no designation telling which jack to use. Sorry this is so incoherent, but I can't seem to post a photo of the back of the head.
  2. heave1
    heave1 New Member
    May 5, 2018
    12
  3. heave1
    heave1 New Member
    May 5, 2018
    12
    Duh. Just figured it out. Told you it was a dumb question.
  4. South Park
    3,526
    3,084
    That is What we are hear for to give bad advice .
    SkyMonkey likes this.
  5. bradley Thomas Wilson
    bradley Thomas Wilson Active Member
    Mar 21, 2020
    159
    191
    Wisconsin
    I have to look every time I plug something in to it, then get my Abacus, take my shoe off, sharpen pencil and I still have trouble. Thankfully they are forgiving.
    South Park, SkyMonkey and SiCoul like this.
  6. Ed Hampton
    Ed Hampton New Member
    Mar 13, 2021
    4
    5
    I have a question regarding the Speaker jacks. Can I plug 2- 8 ohm cabs into the DSL20H? The jacks are labeled 1 x 8 and 2 x 16, nothing for 2 x 8??
    fitz288 likes this.
  7. fitz288
    Apr 7, 2020
    2,771
    6,402
    rahndahbaht the 'Burgh
    :welcome: to the forum.
    You are correct about the jacks, no direct 2x8ohm way to go.
    You would need an adapter to series connect your 2 cabs to the 1 input for 16ohms.
    Amazon.com: Palmer Audio Tools PCABM Passive Cabinet Merger: Musical Instruments
  8. Ed Hampton
    Mar 13, 2021
    4
    5
    Thanks for the Info. I will check out the link that you sent. Also thanks for the welcome message.
  9. Ed Hampton
    Mar 13, 2021
    4
    5
    Fitz288, I just checked out the link....It is no longer available....Bummer, that was exactly what I needed. I'm dyeing to hear both cabs at the same time.
  10. fitz288
    Apr 7, 2020
    2,771
    6,402
    Just do a browser search for "Palmer CAB M Merger"
    Ebay / Reverb / Thomann, etc.
  11. fitz288
    Apr 7, 2020
    2,771
    6,402
    Also, if you "like", "quote", "reply" or call out someone with @ in front of their user, like @Ed Hampton , they will get an alert.
    I just happened to see this thread pop up and decided to see what was new.
  12. Mitchell Pearrow
    14,724
    28,764
    Welcome to the forum
    Hope you find what you’re after, because that’s a cool piece of equipment.
    Cheers
    Mitch
    fitz288 likes this.
  13. ITburst
    ITburst Active Member
    Jul 22, 2021
    71
    104
    Mississauga Canada
    I'm confused also. With my DSL20HR head and MX212A on the way, and reading this thread, I downloaded the manual off of the Marshall site. And no, it does not clearly show where I would plug my amp into the MX212A. The cab is listed as follows: "unit impedance - 8 ohm" {2 X 80 watts 16 ohms}
    Now, does that go into the center jack, the right jack, or does it matter??
    fitz288 likes this.
  14. fitz288
    Apr 7, 2020
    2,771
    6,402
    Either of the center or right jacks labeled 1x8 / 2x16.
    Marshall manuals are notoriously vague, and sometimes wrong.
    But on this amp, either of those jacks is ok to use for the 8 ohm 2x12.
  15. Georgiatec
    Apr 23, 2010
    5,769
    5,559
    If it's the same as the Origin 20h....and it looks exactly the same set-up, then you MUST use the middle socket for an 8 ohm cab. Using the other socket will quickly produce a smell of overheating O/T windings (like cooking kippers).
    Disappointing for Marshall to have such a crap design. Always used to be either or with these outputs.
  16. fitz288
    Apr 7, 2020
    2,771
    6,402
    The DSL20H does not have the screwed up speaker jacks like the Origin20.
    It looks the same, but it works correctly.
  17. ITburst
    Jul 22, 2021
    71
    104
    Mississauga Canada
    I thought I read here just today that the DSL20 had the same messed up jacks.
    I’ll need to search it. That’s what prompted me to download the manual from Marshall
  18. fitz288
    Apr 7, 2020
    2,771
    6,402
    I don't think the DSL20 had this issue.
    I could be wrong - it happens all the time.
    My Origin had the factory / service tech repair & the corrected jack label when I got it used.
    I do use the center jack with my 212 - 8ohm cab.
    The "fix" made ONLY the center jack for 8ohm and center/right for 2x16ohm.
    The Marshall website still shows the old wrong jack labels, but they fixed the manual download.
    The jacks on my DSL look like this and work fine.
  19. Max Gahne
    Max Gahne Well-Known Member
    Dec 1, 2020
    210
    274
    I also plug an 8 ohm cabinet into either 8 ohm jack on my DSL20HR with no problems at all.
