Marshall Code " Patch " Sharing ( Longhand For Now )
Discussion in 'Marshall Amps' started by mazzefr, Jun 16, 2016.
  1. bigbaldy
    bigbaldy New Member
    Jul 6, 2016
    12
    9
    Take a look at this video it seems to cover all the bases-https://www.youtube.com/watch?v=t9jUD0Tp3ew
    TKB likes this.
  2. Sean95m
    Sean95m New Member
    Sep 10, 2016
    13
    11
    I have the footswitch. It's pretty fast when switching channels. If you have it in preset mode there is just a slight delay but if you have it in switch mode it's instant.
    TKB likes this.
  3. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    993
    903
    Brit in California
    I was thinking of something more in line with this. Since you could pass the Volume and perhaps other settings might work with an expression pedal. Or one of the various bluetooth ones that have emerged with the recent popularity of software modeling.
    Something like this affordable Behringer one for $150
    TKB and AJU like this.
  4. Fern
    Fern Member
    Sep 16, 2016
    36
    16
    How cool would it be for Marshall to take their Code series amps to renown guitarists worldwide and ask them to plug in and connect to the Gateway app and create their sound while posting this experience as a video on their site. I know...asking too much but it would have a ton of views. Kinda "What would Slash do if all he had was a guitar, a Code and a Gateway?"
    Quoman7, TKB and Antmax like this.
  5. jodoalien
    jodoalien New Member
    Aug 21, 2016
    4
    Yup, I'm using a G3X in front of mine and not really feeling it with the distortion. I find when using anything higher gain like the fuzz face or muff it gets over saturated and very muddy. I have found a bit of fun using the pedal to control input volume. Putting a booster in front of a clean has worked nicely for getting a bit more crunch.
  6. hcelizondo
    hcelizondo New Member
    Jul 22, 2016
    8
    5
    I'll try using a booster as you are doing to see how it works. Which pre-amp are you using on the code? as I said was trying to get the clean tone from it and basically just using the G3X as a stomp box. For power amp I find myself using the classic 100W or the vintage 30W most of the time and cabinet usually any of the 2 1x12...
  7. jodoalien
    Aug 21, 2016
    4
    Any of the cleans with enough volume can really be brought up to a crunch. The one i've been using the most is the american clean pre-amp.
  8. Jalex
    Jalex New Member
    Jul 9, 2013
    24
    22
    I own a JCM800 4210 combo from 84' and a CODE 25.
    The 4210 has a G12M-70 speaker and is a dual channel JCM800 2205 with spring reverb basically.
    I made 2 patches for the code - one for each channel - using a splitter and having them both side by side.
    I though i share them with you.
    Turn the master to a healthy volume...
    If any of you has such an amp maybe share your thoughts
    clean
    gain 0.2
    bass 9.3
    middle 5.0
    treble 6.8
    jcm 800
    gate 0.0
    classic marshall 100w
    presence 1.5
    resonance 10.0
    cab
    1974cx
    fx
    reverb
    spring
    decay 10 pre 6 tone 6 level 5.5
    boost
    gain 8.2
    bass 6.2
    middle 2.6
    treble 6.8
    jcm800
    gate 0.0
    presence 3.6
    resonance 2.3
    cab
    1974cx
    AJU, Plectrum and TKB like this.
  9. TKB
    TKB Member
    Sep 22, 2016
    53
    38
    Minnesota (summer) Florida (winter)
    This is gold Jalex. Thank you! I owned a JCM2000 DSL 50 at one time and made an "80's Rock" preset based on what I remember. It's my favorite preset although I wish I could have done an A/B test like you did but the Code wasn't out until after I sold it for financial reasons.
  10. rockstardan
    rockstardan New Member
    Oct 29, 2016
    Any suggestions on Neal Schon/Journey rhythm sounds?
  11. Jeremy Blackwell
    Jeremy Blackwell New Member
    Oct 31, 2016
    Try using it in Google Sheets. It's free.
  12. AJU
    AJU Active Member
    May 23, 2016
    186
    50
    Wiltshire, Uk
    Thanks, Jeremy. I guess it will work in google ...
    I personally had excel, have done for years and it creates PDF's which is a much faster way to view, I just thought it might help others.
    I'm still wading through the settings to check if they are all correct. Its very time consuming ;-)
    I'm up to 79 I think so not much further to go, there are 4 errors since the last set i'll finish the checking before I deliver the relevant errors/changes.
  13. Wayne Schwisow
    Wayne Schwisow New Member
    Sep 6, 2016
    5
    5
    I agree. Check out the video. If you switch between different amps and preamps and cabinets, it takes a moment to load new settings. But if you have Plexi and Classic Marshall 100, and then switch between FX with the same amp and preamp there doesn't seem to be a delay.
  14. Wayne Schwisow
    Sep 6, 2016
    5
    5
    Not sure if this will help anybody out, but I took the factory presets list and added 3 columns to the front of it. One for clean, one for crunch and one for OD. I then indicated which preset category each fell into. I did this because I wanted to be able to quickly go to a specific "type" of preset and compare tones. Now I can easily scan for "crunch" presets to compare. Hope it helps others.
    Jalex, Antmax and AJU like this.
  15. Wayne Schwisow
    Sep 6, 2016
    5
    5
    I assume you've found this already, but just in case...
    https://marshallcode.tools
  16. ssolo8
    ssolo8 Member
    Dec 2, 2016
    50
    101
    Texas USA
    God Bless you for all this work you have done for us!! Your day will be 36% smoother for your troubles! Thanks!
    AJU likes this.
  17. AJU
    AJU Active Member
    May 23, 2016
    186
    50
    Wiltshire, Uk
    Nice one Wayne, I like that idea and the explanations table at the top I like that too, I'm sure @mazzefr will notice this and put a link at the front to this.
    I'm still wading through Andy's original list (I got sidetracked by wifey and a paint brush), there are some discrepancies detailed earlier in this thread though did you pick them up in your list?. I'm sure everyone is aware that patches 71/72 marked "X" are not factory settings.
    Nice ideas though, thanks.
    I'll try and pick up the proofing again soon...
  18. stw500
    stw500 Member
    May 27, 2016
    82
    18
    Some days ago I could put the Marshall AS100D and the code 50 side to side. I know one is a acoustic amp and one for electric but I tried to get the code 50 sound similar to the as100d but without good result. The As100D sounded much more warmer than the code no matter which setup I tried. So does anyone have a good setup/patch for sounding the code really warm?
  19. Antmax
    Aug 7, 2015
    993
    903
    Brit in California
    What kind of pick are you using. That can make a huge difference to the sound of your guitar. More than changing pickups.
    I mostly use JazzIII's. The standard red one is kind of middle of the road general purpose. A Jazz III made from Ultex (the semi opaque yellowish ones) produce a warmer sound taking away some of the highs they can sound pretty smooth. The prime tone Jazz III's are quite bright and punchy with a lot of detail but can sound a bit brittle. Tortex sounds in between the standard red and the Ultex.
    It might be worth getting some pick variety packs like the Dunlop ones to see what kinds of tone variations you can get with your particular guitar and pickups.
  20. stw500
    stw500 Member
    May 27, 2016
    82
    18
    Thx for the answer. But when i tried both amps i used the same pick, so the sound produced from the guitar was the same. But if there is no other way to sound the code warmer (e.g. like the as100d) i will try using another pick.
    snowone and Quoman7 like this.
