Marshall Code 100 no sound
Discussion in 'Marshall Amps' started by Roshtyaak, May 18, 2021.
  1. Roshtyaak
    Roshtyaak New Member
    May 18, 2021
    2
    Just bought the combo.. Then I realised no sound coming from the amp. The headphones output work perfectly, can edit presets, join via Bluetooth etc. Any help appreciated. Thanks.
  2. fitz288
    fitz288 Well, Known Member Silver Supporting Member
    Apr 7, 2020
    1,784
    3,909
    the 'Burgh
    :welcome: to the forum.
    If you just bought it, can you return it?
  3. Roshtyaak
    May 18, 2021
    2
    Yes I can, but I don’t want to wait next 2 weeks dealing with the refund. I have been so exited about the combo. That issue has completely ruined my day. Just wanna know, If there is another solution, haha
  4. fitz288
    Apr 7, 2020
    1,784
    3,909
    the 'Burgh
    First things I would check is for a loose speaker wire, or a blown fuse.
    Have you looked inside yet?
    PelliX likes this.
  5. Gunner64
    Nov 16, 2013
    7,144
    9,828
    Midwest, USA
    First off, Don't void your warranty by monkeying around in there. Is the 100 a closed back like the 50? I know the 50 I had you had to open the thing up to see the speaker, and its connection.
    I would Check the settings of everything first, (there is a learning curve with the codes, lotsa tweakable stuff) just to be certain a setting isn't clamping your signal to the speaker. Myself I would return it if it is actually defective.
  6. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    257
    346
    I believe that the CODE series only have a single fuse - the one on the PSU board. If the headphone out works, it's not that fuse. Any chance of doing a firmware up/downgrade? And, as @fitz288 suggested, check for loose wires. No idea how the warranty is affected by that. On valve amps Marshall is fine with one removing the back panel.
    fitz288 likes this.
