Hi everyone,
I'm a Marshall amp guy. Specifically, I am a single channel JCM 800 guy. In 1993 I bought a used 50 watt JCM 2204 for $300 in Hollywood (I'm from LA). I've played hundreds of gigs since 1994 with either a 2204 or 2203.
About a year ago I picked up a 1977 50-watt JMP 1987. I really couldn't gel with this amp for well over a year.....until I set the volume on channel 1 (bright channel) to at least 7 on the dial...Man, what a difference. The amp came alive, it filled out nicely, notes sustained nicely, and the harmonics that had been missing decided to finally show up. Also, the amp sounded muffled through a 4x12 with greenbacks before, but now they sound clear, crisp and full. I had no idea that volume was the key to this amp. I'm using an attenuator to tame the actual volume but it's still loud...only knocking back about 3db with the attenuator.
Anyway, I would like to hear from Marshall heads that primarily use 1987 amps or 1959 amps. These amps are just a different beast to the single channel 800's.
