Make this amp great again.
Discussion in 'The Workbench' started by Marcell, Jul 10, 2020.
  1. Marcell
    Marcell Active Member
    Feb 11, 2012
    346
    147
    Holland
    Hey there.
    What is advisble when you buy a secondhand amp and wanna do great maintenance on it. It's a amp from the 90's 9100.
    Tubecheck
    Filtercaps?
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,588
    1,312
    It’s not a bad idea to check the bias. I would do a visual inspection but that would only tell you if everything looked good. How does it sound?
  3. pedecamp
    15,229
    12,812
    Power it on and check the bias and see how it sounds. If it sounds bad get new tubes. Also clean all pots and input jacks with Deoxit. Do a visual inspection of the internals to make sure everything looks good, no bulges, burns or leaks. If you got cash to spare have a pro tech look it over if youre not confident to do it yourself.
    TXOldRedRocker likes this.
  4. Marcell
    Feb 11, 2012
    346
    147
    Holland
    The only experience I have is running a jcm900 on el34 with change of a bias resistor... not in things how to get a amp back to shape..deoxit is something I will do..maybe a needlefile to gently work the connections..jacks and tubesockets. I have a bias probe so that can I do. What to change after 30 years of service?
  5. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    735
    855
    Iowa
    Like you said, tubes and filter caps would be the first things to look at. Open it up and look at the filter caps. I'd almost do that before I even powered it on. If you see a bulge or a leak then I'd replace them. It's fairly easy to do yourself and not too expensive of a repair.
  6. South Park
    2,907
    2,407
    Start with the basics . If the amp sounds good may not have to do much .
  7. Chris-in-LA
    Jul 19, 2018
    1,588
    1,312
    You still didn’t tell us if there’s an actual problem. If the bias checks out and it sounds good, I’d just use it as is.
  8. mickeydg5
    mickeydg5 Well-Known Member
    24,922
    11,855
    And it is a model 9100. Its not rocket science but a little different than the run of the mill amplifier.
  9. Marcell
    Feb 11, 2012
    346
    147
    Holland
    Itś a 9200.. I had a 9100... but sold it.
    I just bought it.. I just want to do a great check so I don't have issues later. It has Tung sol tubes so I think thats oke. Other things to look for? I don't like to do repetitions and have problems I could have avoid in the first place... Don't you hate it when some bandmember hasn't sort out his stuff?
  10. mickeydg5
    24,922
    11,855
    So you have baised a 9100 or 9200 before and you know about the balancing?
    Marcell likes this.
  11. neikeel
    4,641
    3,040
    Is this the version that you can run both in stereo and in mono (left side only)? As it is just a power amp there is nothing special. Decent matched quad (per side) of tubes, filter caps in good condition and bias set in correct range for your tubes. I have a 9000 series 50/50 knocking around somewhere, I power it up every now and again to keep it sweet. I am limited in that I do not have a dedicated stereo preamp for it (waiting for something decent but cheap to throw itself at me).
    What are you using for a preamp?
  12. Marcell
    Feb 11, 2012
    346
    147
    Holland
    The Filtercaps are toast... I can move them 1/2 inch...they are wobbeling in there.. 220uF 4 pro side.
    tce63 likes this.
  13. Marcell
    Feb 11, 2012
    346
    147
    Holland
    I'm using a digitech gsp1101 for preamp..
  14. Marcell
    Feb 11, 2012
    346
    147
    Holland
  15. Chris-in-LA
    Jul 19, 2018
    1,588
    1,312
    Not sure that wobbly means anything other than the bracket or solder connection can be loose. Check all the connections. Also, does the amp work? How does it sound?
  16. Marcell
    Feb 11, 2012
    346
    147
    Holland
    I
    It sounds oke, just noisy pots and lack of power.
  17. Chris-in-LA
    Jul 19, 2018
    1,588
    1,312
    Have you checked the bias?
  18. Marcell
    Feb 11, 2012
    346
    147
    Holland
    N
    No, first I want to check thoose caps, maybe resolder them. I have to take it in my shed, to do good observation of whats going on.
  19. Chris-in-LA
    Jul 19, 2018
    1,588
    1,312
    Good idea.
  20. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    2,097
    2,085
    The Institute for the Very, Very, Very Nervous
    Always check that the fuses are the correct size.
    Justin Whitstine and Marcell like this.
