main fuse value for a Carvin sx100
Discussion in 'The Workbench' started by marshalltsl, Jun 3, 2020.
  1. marshalltsl
    marshalltsl Well-Known Member
    Apr 6, 2012
    608
    745
    Catalonia
    Hi
    I would like know the main fuse value from a Carvin sx100 mosfet. It's a combo. Solid state. It's to use in Europe. The amp have one of 4A. I think it's to much big. It has a voltage selector. The 4A fuse it's ok. The amp works but It need replace jack inputs.
    Thanks in advance.
  2. ampmadscientist
    18,207
    12,283
    The schematic says 1.5 amp fuse, 240 volt input.
    https://cdn.shopify.com/s/files/1/0476/5297/files/sx-schematics-all.pdf?2270
    https://carvinaudio.com/pages/guitar-amp-schematics
    marshalltsl likes this.
  3. mickeydg5
    mickeydg5 Well-Known Member
    24,964
    11,864
  4. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    Thanks AMD!
    You know I have a friend that he have a black LP Custom with a crack on the neck. I posted a thread on the forum. Yesterday, he cames up to my local place with this amp because he said he had a broken speaker. :blah:
  5. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    A 1.5A fuse have sence. But I can't see It on the schematics righ now.
  6. ampmadscientist
    18,207
    12,283
    1.5 amp 240 volts
    3 amp 120 volts
    Schematic says: "sx100."
    marshalltsl and mickeydg5 like this.
  7. ampmadscientist
    18,207
    12,283
    1.5 amp for 240 mains voltage.
    3 amp for 120 mains voltage
  8. ampmadscientist
    18,207
    12,283
  9. mickeydg5
    24,964
    11,864
    Ah, good. I did not see that in the title block. I had noticed the other SX schematics had a bit different design from the looks of things but if 1.5A is for all then a-ok.
    :thumbs:
  10. mickeydg5
    24,964
    11,864
  11. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    Thanks guys!
  12. ampmadscientist
    18,207
    12,283
    Looks like 2 amp now days....
  13. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    Ok. The funy think. On this amplifier someone changed the inputs. Someone installed stereo jacks! Amazing! Removing the stock inputs from pcb board IMG_20200531_203859_116_copy_1008x754.jpg IMG_20200531_204732_630_copy_1008x754.jpg damaged the tracks. That's why the amplifier fails. I hope I can fix it.
  14. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    I fixed It. I replaced input a/b and input b. The amp sound properly. The footswitch it's ok. I tested all pots and some needs a clean. Then I disassembled the amp again and clean all pots, switchs and board. But after that the footswich don't work. I test the footswich. It's ok. The problem it's on the amp.
    PLEASE I need HELP. Probably I burned a IC. I don't know. I waited several minutes after clean It to test the amp.
  15. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
    Solved! :agreed:
    Thanks for the help.
  16. marshalltsl
    Apr 6, 2012
    608
    745
    Catalonia
