Lynch Mod Tube Module for Marshall Amps
Discussion in 'The Tone Zone' started by crossroadsnyc, Feb 20, 2021.
  1. Txdslguy
    Txdslguy Member
    Feb 2, 2021
    34
    37
    10 4
  2. David Szabados
    David Szabados Member Platinum Supporting Member
    Dec 11, 2019
    36
    62
    The HMV2 Evo has slightly more bass cut then the Lynch Mod as well as being $100 less :)
    The standard wired model will work both in the 1959HW as well as the SC heads.
    It will be a different type of effect than hitting the front end with the pedal since we are layering a gain stage on V2 and not pushing all sections. So it will add gain but still be articulate. Both ways are good however - just different flavors of tones and gain.
  3. David Szabados
    Dec 11, 2019
    36
    62
    I just had the folks at Marshall go through the Origin and it doesn’t work in stock configuration. I have no clue in the modded version of the circuit but. It’s not just the circuit concern, but also the power supply and other elements. In the stock origin, my Marshall contact told me it gave off a synth type noise effect and definitely is not compatible.
  4. Txdslguy
    Txdslguy Member
    Feb 2, 2021
    34
    37
    10-4. Maybe @burger could help.
  5. burger
    burger Active Member
    Jan 6, 2018
    37
    115
    In my mod V2 is wired backwards as compared to a 2203/2204 Marshall. This is because I am repurposing the cathode follower that was being used to drive the FX send (V2a) as a CF to drive the tone stack.
    David Szabados likes this.
  6. David Szabados
    Dec 11, 2019
    36
    62
    So it seems possible that the reverse wire version of the Hot Mod V2 Evo might work with your modded amp version. Because that’s exactly the configuration the HMV2E needs to “see” in order to make a connection. So you are driving the tone stack off of pin 2 rather than pin 7?
  7. burger
    Jan 6, 2018
    37
    115
    Yes. Remember V2a is a cathode follower for the FX loop, so I'm reusing it to drive the tone stack instead - after the signal get's through V2b.
  8. Chrome
    Chrome Firebird Freak Gold Supporting Member
    Aug 29, 2017
    485
    818
    greeneville Tennessee
    I really like the lunch mod video, I could see it working well on my JMP (1987) but not sure I would need it on my JMP(2204) I just bought it and waiting on its arrival. The whole reason I got the 2204 is I know with the cascaded preamp I will have more gain. I play most southern rock so I am on the fence with needing more gain.
  9. Vinsanitizer
    Vinsanitizer ______. sṓzō .______ Double Platinum Supporting Member VIP Member
    Oct 19, 2012
    29,205
    24,746
    I'd like to hear it loaded with 12AU7's.
    Lemme guess: $299.99?
  10. David Szabados
    Dec 11, 2019
    36
    62
    $199 for the HMV2E, $299 for hand wired Lynch. I had one person who chose to use 12AU7s and liked it, but most others like 12AX7s as it’s tuned for that.
  11. Vinsanitizer
    Oct 19, 2012
    29,205
    24,746
    I was joking. Lo gain tubes in a high gain device.
  12. David Szabados
    Dec 11, 2019
    36
    62
    You’d think but no joke I have a customer that went with that configuration! Go figure, but I guess we all have different taste I suppose :)
  13. Vinsanitizer
    Oct 19, 2012
    29,205
    24,746
    If it weren't for stupid customers (with delicious credit cards) there'd be no businesses.
