Lockdown Troubleshooting
Discussion in 'The Workbench' started by assaf110, Apr 16, 2020.
  1. assaf110
    assaf110 Well-Known Member
    Feb 3, 2017
    176
    281
    Hi all,
    Looking for some help troubleshooting a Princeton reverb kit build (Mojotone).
    I have built a couple of tweed amps before (5e3, champ etc.) a bunch of pedals & other stuff, so my soldering & general technical abilities are good. Having said that, a faulty joint or wiring error is always possible.
    The amp have some serious issues, presumably in the power section. I'm getting some wild voltages, as you can see in the chart attached. The tubes seems to glow OK, the speaker make no sound at all.
    If this thread is better off in a different forum, please feel free to direct me to a more appropriate place...
    Thanks & good health to you and all your loved ones,
  2. Travis398
    Travis398 Well-Known Member
    Dec 7, 2011
    897
    1,233
    USA
    Is the CT grounded? hard to tell on the picture if there is a jumper or if it's isolated.
    neikeel and johan.b like this.
  3. assaf110
    Feb 3, 2017
    176
    281
    Do you mean the PT red&yellow tap? Yes, it’s grounded.
    Travis398 likes this.
  4. Ken Underwood
    Oct 16, 2013
    630
    1,503
    Annesley North Notts UK
    GZ34 pins 6&7 approx 328v A/C, then if that is OK then you should find approx 300v D/C on the cathode pin 8.
    Thats the first thing to be getting on with for starters
  5. South Park
    3,130
    2,632
    That 800 volt reading you might have a voltage doubler from the filter caps trace out the power rail
  6. neikeel
    4,863
    3,256
    Those voltages really are off.
    It might seem daft but double check the orientation of your rectifier wires in relation to the correct pin numbers.
    The HT is very asymetric. What happens if you temporarily unhook the bias feed wire, or simply remove the rectifier and measure ac between the pins and then each limb to ground?
    assaf110 likes this.
  7. Ken Underwood
    Oct 16, 2013
    630
    1,503
    Just do the basics first as its always a good idea to get the PSU working properly, then the rest will fall into place, dont go looking too deep
  8. ampmadscientist
    17,865
    12,058
    Let's see close up pictures of the first 3 large tube sockets.
    There is not enough detail to trace the wires to each tube socket pin.
    Apparently the wires to the sockets may be positioned wrong....
  9. assaf110
    Feb 3, 2017
    176
    281
  10. assaf110
    Feb 3, 2017
    176
    281
    When I take the GZ34 out and measure I get the same - 370v (pin 6), 234v (pin 4).
  11. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,735
    1,987
    Södertälje, Sweden
    Is this one truly going to ground or might it be "not connected" to the ground next to it? 20200416_175006.jpg
    J Saw likes this.
  12. ampmadscientist
    17,865
    12,058
  13. johan.b
    Feb 21, 2015
    1,735
    1,987
    Södertälje, Sweden
    Insulation pooking through?
  14. ampmadscientist
    17,865
    12,058
    This red/yellow stripe wire should be connected to ground, I think you are correct.
  15. ampmadscientist
    17,865
    12,058
    Red / yellow stripe wire needs to be grounded to chassis.
  16. Ken Underwood
    Oct 16, 2013
    630
    1,503
    Across the two red wires on the GZ34 what does it say on your meter, dont forget you are reading AC not DC
  17. assaf110
    Feb 3, 2017
    176
    281
    You guys are ace!
    It’s the first time for me using this 3 lug earth that came in the kit. I assumed they were all conected. Well it’s not the case and the PT CT is not grounded. I’ll sort that out & report back.
    J Saw and johan.b like this.
  18. ampmadscientist
    17,865
    12,058
  19. johan.b
    Feb 21, 2015
    1,735
    1,987
    Södertälje, Sweden
    The black wire, I assume, is ground for the bias?... lacking ground on both those points would explain the odd readings you've got.
    J
  20. assaf110
    Feb 3, 2017
    176
    281
    690vac
    Ken Underwood likes this.
