Lead15 Micro stack speaker outs...
Discussion in 'Marshall Amps' started by rj ryno, Jul 29, 2021.
  1. rj ryno
    rj ryno New Member
    Jul 29, 2021
    8
    11
    Hi all!
    new marshall owner here and new to the forum. I recently got a couple mini stacks, the Lead 15 and MG15MSII. The stock 10's are actually pretty darn good...for many years I always thought they were 8's in these. I recently swapped in a 12" celestion (8ohms) and both the outputs on the head say 16ohms, and no lower than 8 to be used. So my question is... can I use the stock 16 ohm 10 inch cab and the modded 8ohm 12 inch cab together on the head? Thought I would ask here before trying it....I already plugged in the modded 12" alone and works fine.
  2. Matthews Guitars
    4,437
    6,673
    Solid State amps like those should be pretty tolerant of varying speaker impedances. As long as you're above a total speaker load of 4 ohms (2 8s or larger) you'll be fine.
    Those love G10 Greenbacks. For a 10 inch speaker I would pick G10 Greenbacks or G10 Creambacks. They sound so good, I'm not sure that going to G12 Greenbacks is actually worth the effort to modify the cabinets.
  3. rj ryno
    rj ryno New Member
    Jul 29, 2021
    8
    11
    ok thanks, I just plugged both of them in and seems fine. Yeah, I don't think I'll be putting 12's in the other 3 cabs, but greenback 10's sound like a good match. We'll see...
  4. Matthews Guitars
    4,437
    6,673
    Gotta be honest here: 70/80s are pretty poor choices for pretty much ANYTHING. Except they work well in a Fender amp, from my experience.
  5. fitz288
    Apr 7, 2020
    2,771
    6,402
    rahndahbaht the 'Burgh
    I have a Lead 15 and I replaced the stock 16ohm speakers with 8ohm Ten-30's for a while.
    They worked fine, but then I replaced those with 16ohm VT jr.'s - way better.
    As @Matthews Guitars said, as long as the total impedance is at least 4ohm, the amp should be fine.
    I'll also agree that the 12" 70-80 is not exactly an upgrade...
    I could be wrong, but from what I've heard, solid state amps just get louder with lower impedance speakers.
    I also have a MG15CFMS, but I gutted that and put my Code25 and some 10" FRFR speakers in it.
    Oh yeah, :welcome: to the forum.
    rj ryno and Mitchell Pearrow like this.
  6. Mitchell Pearrow
    14,724
    28,764
    :cheers:
    :welcome:
    TO THE FORUM
    Marshall rules the nest in my opinion.
    Glad to have you aboard.
    Cheers
    Mitch
    rj ryno and fitz288 like this.
  7. Mitchell Pearrow
    14,724
    28,764
    And by the way I run my 3210’s (lead 100 mosfet’s at a 4 ohm load)
    They are the big brother’s of the lead 15.
    Congratulations on your Marshall amp my friend.
    Cheers
    Mitch
  8. rj ryno
    rj ryno New Member
    Jul 29, 2021
    8
    11
    Yeah kinda figured that...I bought a used Traynor YCV40 a couple months ago and the previous owner had swapped in an eminence cannabis rex. The celestion he gave to me for free, since it was the amps original and has since been a spare until today. Not sure if the eminence is any better though.
  9. mickeydg5
    mickeydg5 Well-Known Member
    26,634
    13,807
    united States of America
    The MG amplifier can handle 4 ohms but the LEAD solid state amplifier can only go to 8 ohms minimum.
  10. Mitchell Pearrow
    14,724
    28,764
    Really ?
    I have been running both of mine at 4 ohms since I got them, about 5 years now.
    And so far so good, no problems as of yet.
    Cheers
    fitz288 likes this.
  11. SkyMonkey
    3,550
    4,891
    I think even the MG15MSII needs a total load of 8 ohms minimum (1 x 8, or 2 x 16).
    One 8 and one 16 would make a load of 5.33 ohms, and uneven power distribution.
    I used this site: https://geoffthegreygeek.com/calculator-speakers-in-parallel/#jumpto
  12. fitz288
    Apr 7, 2020
    2,771
    6,402
    Mine looks exactly like this.
    I ran the 2 ~ 8 ohm Ten-30's for a couple of months.
    I never dimed it for hours on end, I have louder amps if I want loud.
    Maybe I just got lucky? :shrug:
    Wouldn't hurt to just use 16ohm speakers though.
  13. mickeydg5
    26,634
    13,807
    My answer was based on Marshall manuals.
    Any amplifier dimed will portray different characteristics and loading (effects).
    You may take your chances as your prerogative.
    SkyMonkey and Mitchell Pearrow like this.
  14. Mitchell Pearrow
    14,724
    28,764
    I am not playing to any audience.
    But your advice is well taken.
    So far I have not had to turn my 3210’s over 3 on the dial.
    So I feel safe.
    Cheers
    SkyMonkey likes this.
  15. mickeydg5
    26,634
    13,807
    A mismatch on any amplifier played at the low end of signal strength is never a problem. However when you start maximizing signal/power then things are tested and the weakest link breaks first.
    That follows the law, of electronics.
    Mitchell Pearrow and SkyMonkey like this.
