Rocktane
Can the Lead 12 be fitted with an effects loop?
depends on the expense.Um, why?
Even if possible, would the results justify the expense?
a amp that cheap i dont see how. a good working loop would only add valueThe mod would probably decrease the value of the amp.
Good question. What IS the expense? A couple of jacks? Complete Metro loop kit? I don't know what it would take. I agree that spending $100 on a $200 amp might not be a great idea.Um, why?
I completely understand.As to why.... I like delay and reverb in the loop.
explain with pics?Yes. I modded mine to be a tube amp. Wish I had a loop installed as well.
I think there are a few original parts left...Transformer? And of course the chassis. I still have the original parts in a box somewhere so it should be reversible.oh so its just a head cab of a marshall then?
i was thinking somehow the guts were used to build
a tube amp.
I dont see a line ouput, except a DI output from the power amp. Dont use that.I found this schematic on another forum. Obviously, I know nothing about this stuff but have modded pedals.
Could the send come off the Line Out Jack, and return go to C8 on the board?
But if you just take the signal from the wiper of the volume pot, and use that as FXsend, and use C8 as the FXreturn, it wil prolly work. Allbeit a bit low-fi and maybe with lowish output. But you wouldnt even need electronics, just two jacks.
For a better solution you need a buffer for the output and a recovery stage fir the return to bring to signal back up. This would involve two opamp of discrete gain stages.
A metro-type loop needs a high voltage supply which is not available in that amp…atleast not high enough I think.
SPARK 40.Thank you, this helps a lot! I really appreciate it. This is pretty much what I was expecting to hear. Even wondered if putting a GE7 EQ in the loop would help as a buffer and raise the signal level. I should probably just look at other options for a living room amp that is somewhere between a desktop (THR-10) size, and a full-size combo.
+1But if you just take the signal from the wiper of the volume pot, and use that as FXsend, and use C8 as the FXreturn, it wil prolly work. Allbeit a bit low-fi and maybe with lowish output. But you wouldnt even need electronics, just two jacks.
if you can show me a $200 Lead 12 head these days, I'd be impressedGood question. What IS the expense? A couple of jacks? Complete Metro loop kit? I don't know what it would take. I agree that spending $100 on a $200 amp might not be a great idea.
This would be living room amp and would not be run with any other amps.
