JVM410c, Took in for service- The mode settings have changed...
Discussion in 'Marshall Amps' started by Ty Curtis, Oct 28, 2020.
  1. Ty Curtis
    Ty Curtis New Member
    Aug 20, 2018
    12
    Hi Folks,
    I took my JVM 410c to get it serviced. Upon turning the amp on and playing it, I found some usual behaviors. On the Clean channel when I scroll through the modes: Green is fine. When I press the mode selector button again for the orange mode, the Master Volume jumps to the 2nd Master Volume. When I press the mode selector button to select the red mode, it jumps back to the first Master Volume. It didn't do this before I took it in. How do I get it to return to the natural setting? Thanks!
  2. Ty Curtis
    Aug 20, 2018
    12
    Ok- It was my pilot error. Somehow the Master volumes were selected while being serviced. I didn't realize they stayed until reselected.
    Jethro Rocker likes this.
  3. Jethro Rocker
    8,754
    11,291
    If you have a footswitch it should also remember the modes you last used, they get programmed in the switch itself.
  4. Soporific
    Soporific New Member
    Feb 6, 2018
    9
    Found this to be handy after changing things then not using the amp for a bit and forgetting what I had setup. Edited from the manual.
    Factory reset:
    This will erase all the MIDI presets and set MIDI reception channel to #1.
    Please note that once the memory is erased it cannot be recovered.
    Switch the amplifier off (power switch off, not standby switch).
    Press and hold CLEAN CHANNEL/ GAIN switch.
    Switch the amplifier on (power switch on, not standby switch).
    The 4 channel LEDs will glow red.
    Release the switch.
    To confirm the factory reset press CRUNCH MODE switch.
    If you want to abort, press any other key.
    Footswitch factory reset:
    Unplug the footswitch at any of the cable sides.
    Press and hold the switch #6 (right switch).
    Plug in the footswitch cord.
    Release the switch and the FX led will start blinking.
    If you want to erase the footswitch memory press the switch #5.
    To keep the memory press any of the #1 to #4 switches.
    Release the switch and the footswitch will synchronise with the amplifier.
    The factory default is as follows:
    FSW #1: Clean Mode
    FSW #2: Crunch Mode
    FSW #3: OD1 Mode
    FSW #4: OD2 Mode
    FSW #5: Master
    FSW #6: Reverb
