Jvm noises intermittent
Daniel55
I have this intermittent noise coming for the amp. I had the amp just idle. Guitar hooked up effects loop active. Pops, clicks fuzzy noises coming in and out. So I unhooked my effects board. Still was there. Disengaged the effects loop button. Didn’t change. I switched channels throughout the amp and no change. It didn’t get louder or softer when master volume was up and didn’t change when the channel volume was up. Stayed the same volume. I tried a different speaker cab with a different cable and still there. It’s a combo by the way. The problem is it comes and goes. It was super noisy before and I videoed it. Now it’s quiet again. Not sure where to start because it doesn’t change when the volume is adjusted. Any thoughts? I’d take it to a tech but if it’s intermittent it may not happen when I take it lol thanks for any suggestions.
saxon68
VIP in training. J/K
West Virginia
I’ve heard that cleaning the pins (using proper cleaning spray) on the tubes and inserting / removing a few times can clear up some of this type problem.
