JVM mod OD2 to OD1
Discussion in 'The Workbench' started by Shae201, Aug 4, 2020.
  1. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    661
    699
    What is the wattage of the resistor and the voltage for the capacitors for this mod? Screenshot_20200725-194723~2.png
  2. JM5010
    JM5010 Active Member
    Nov 11, 2017
    276
    46
    1/2 watt for resistors, 500V for the caps.
  3. Shae201
    Dec 20, 2015
    661
    699
    Tha
    thanks bro.
    JM5010 likes this.
  4. Shae201
    Dec 20, 2015
    661
    699
    I'm kinda digging OD2 orange channel for Slayer type metal. I know when I had a 410H I like the OD1 channel better but I guess if I can't try it because of having a 210H then I won't miss it. Can you make it footswitchable to go between OD2 and the OD1 mod?
  5. JM5010
    Nov 11, 2017
    276
    46
    I
    You can, but it would require drilling holes for extra switches. Switches may need to be rated for 250V or higher since they will be switching the value of coupling caps, which feed off of the plates.
    EDIT: And maybe a 50K high voltage pot for the slope resistor. This way you can go from 33k to 47k, and lower.
  6. Shae201
    Dec 20, 2015
    661
    699
    Does this look right to you?
  7. Shae201
    Dec 20, 2015
    661
    699
  8. JM5010
    Nov 11, 2017
    276
    46
    Can you upload a close up image? It's very hard to see what you did.
  9. JM5010
    Nov 11, 2017
    276
    46
    Looks like R44 is a 1K resistor, not 33K.
    Change it to 33k.
  10. Shae201
    Dec 20, 2015
    661
    699
    Sorry, I haven't done the mods these are all still factory components I just wanted to make sure that these are the right ones
