Just bought 1970 Marshall Major
Discussion in 'Let's Talk Vintage' started by bobyoung53, Apr 30, 2021.
  1. Ned B
    Ned B Well-Known Member
    Nov 19, 2012
    274
    296
    Mine is from 11/69 and has the "fish tail" selector. I have only seen those on US export amps from late '69 to early '70. I'm running KT120s.
    mAx___ and bobyoung53 like this.
  2. bobyoung53
    bobyoung53 New Member
    Apr 30, 2021
    10
    18
    Thanks for the reply, two questions, are those 'fish tale" selectors available anywhere? No? Didn't think so. :D My first one also had that selector.
    Also I assume the power transformer is strong enough for the extra filament current the KT120's use? How hot does the power tranny get when you run it?
  3. Ned B
    Nov 19, 2012
    274
    296
    I run it pretty clean. I have not played it long at loud volumes. You can't be in the same room even with ear plugs it is so loud. Also I would think it would arc if driven hard for a long time. My bass player uses it when we rehearse at my house and it does sound fabulous.
    playloud likes this.
  4. gtomax
    gtomax New Member
    Apr 19, 2020
    11
    4
    I've got a few big amps like a 1968 DR201 and 1969 Orange/Matamp using KT88s. I might be blowing my cover but I've got a few sets already - you can find NOS GEC TT21 tubes which are KT88's with an anode cap. You can buy an adapter per tube on ebay and these are fabulous tubes that are still currently obtainable as long as your cabinet supports the additional height of the adapter and cap. Looks like the Major should be OK, worth a shot to check it out.
    I've found TT21s with original packaging around $150ea at NOS specs and they'll last.
  5. playloud
    playloud Member
    Dec 28, 2020
    61
    64
    At the risk of derailing the thread, do you know if those "6CA7"s (or the MkIIs) are beam tetrodes? I'd probably get a set for variety if so, but I've seen them listed as pentodes in a couple of places (e.g. here).
  6. yladrd61
    yladrd61 Well-Known Member
    Jun 20, 2010
    2,025
    1,016
    Tacoma-ish, WA
    I know the original Sylvania 6CA7s that I replaced them with were beam tetrodes, not sure on the Psvane Mk I or Mk II. Psvane also made a very nice reissue of the early metal base Phillips EL34s if you are looking for a pentode.
  7. playloud
    playloud Member
    Dec 28, 2020
    61
    64
    Yes, those look really nice too. I'd actually prefer beam tetrodes though, as I'm already pretty happy with Winged Cs for the pentode sound.
  8. yladrd61
    Jun 20, 2010
    2,025
    1,016
    Tacoma-ish, WA
    I would highly recommend the Winged C 6L6's however they are getting very hard to find.
    playloud and Valvelust like this.
  9. Valvelust
    Valvelust Well-Known Member
    Feb 9, 2010
    603
    391
    In the midst of trees
    It all depends on how far you want to go, hard to tell what wave form comes out of the EBS you might be okay as long as you don't push it past 4-5.
