JTM50 model 1987 and JTM Superlead model 1959
Discussion in 'Building the Classics' started by Jason deBroux, Sep 19, 2021.
  1. Jason deBroux
    Jason deBroux Member
    Aug 26, 2021
    66
    44
    Am I safe in assuming HT means high tension ?
  2. yladrd61
    yladrd61 Well-Known Member
    Jun 20, 2010
    2,210
    1,421
    Tacoma-ish, WA
    Also the split cathode 1987 and 1959 were JMP which were the models which were made after the shared cathode JTM50 and JTM100.
  3. william vogel
    Dec 18, 2016
    649
    718
    A 100 watt is only 3db louder, I’ll agree with this statement but a 100 watt IS twice as powerful. A 100 watt Marshall or Hiwatt shakes things off the shelves in my shop. I have a 50 watt, a 45/100 and an 18 watt and although the 18 watt is loud the 45/100 (75 watts) kills it. A 100 watt has a fuller bottom end and is squishy. They idle between 465 and 490 volts, sometimes higher, over 500 volts and sag 100 volts at full stride. A 50 watt idles between 420 and 450 volts and sags about 50 volts. They feel a bit different.
  4. Spanngitter
    Spanngitter Member
    Jan 22, 2019
    74
    54
    Upper Palatinate / Bavaria
    There is also 1987/2204 Series out there (mainly with a P SN) where B+ runs only around 380V, you barely get it to 400V by running the Amp in 220V Setting instead of 240V.
    PT is apparenlty Drake, couldn't elaborate if 1202-164 or 324 as the marking on the 3 units I had so far was quite faded...
