JTM45 RI Bias
Discussion in 'The Workbench' started by musicman, Jan 11, 2011.
  1. Alabama Thunderpussy
    Alabama Thunderpussy Well-Known Member
    Oct 23, 2010
    2,069
    1,059
    Northern CA
    Yeah nevermind the plate voltage or current. Just set it to -48VDC :lol:
  2. Birk
    Birk New Member
    Mar 20, 2009
    75
    Norway
    I've replaced 5881 for KT-66 in my JTM45RI some time ago. Belive I set bias for about 45 mA, if memory serves me right.
  3. MajorNut1967
    MajorNut1967 New Member
    Jul 30, 2009
    3,883
    338
    Hi Birk,
    Do you remember what your plate voltages with the KT66?
  4. musicman
    musicman Active Member
    Nov 9, 2009
    784
    95
    Peoples Republic of South Yorkshire UK
    I tried Svetlana Winged C 6L6 but they are way too clean.
    Currently waiting for a pair of JAN Philips 5881's.
  5. Birk
    Birk New Member
    Mar 20, 2009
    75
    Norway
    Checked my notes now, it appeared to 45mA and 391 volts.
    I can not remember if I adjusted the bias lower after that.
  6. musicman
    Nov 9, 2009
    784
    95
    25w / 391v = 64ma x 70% = 45ma
    Your voltage is quite a lot lower than mine @ 424v
  7. MajorNut1967
    Jul 30, 2009
    3,883
    338
    I bet it sounds great though! It's not necessary to have massive plate voltages to have great tone.
  8. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Having tube GAS huh? those are good tubes.
  9. musicman
    Nov 9, 2009
    784
    95
    Yes, Derek at Watford Valves recommended them and has given me a decent discount.
    The = C = are for sale if anyone is interested.
    Very well matched and only been used for an hour or so.
  10. Birk
    Birk New Member
    Mar 20, 2009
    75
    Norway
    Well, first time around, the voltage was 351 volts.
    After some reseach, I found out that my 8 ohm cab wasn't 8 ohm at all, and used another cab instead, then I changed the rectifier tube.
    I don't know why the voltage is that low, but according to my friend (who is an amptech), it's ok.
    The JTM45 is now for sale btw...
  11. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Don't worry guys my 1968 Model 1987 read only 383vdc on the plates, and it sounds tits!
  12. musicman
    Nov 9, 2009
    784
    95
    So the JAN Philips 6L6WGB (5881) arrived today.
    I was surprised how small they are.
    Anyway, put them in and biased to 38ma (23w / 424v x 0.7 = 38ma).
    I'm not overly impressed, they're quite clean.
    I actually prefer the sound of the Sovtek 5881's that were in the amp.
    Is 38ma right or do the JAN Philips need to be biased "hotter" ?
  13. MajorNut1967
    Jul 30, 2009
    3,883
    338
    If they are real JAN Philips 6L6WGB, they are a 26 watt tubes. lets bump up to 44mA and it is a 6L6 variant not a true 5881; so it will be very clean.
  14. musicman
    Nov 9, 2009
    784
    95
    This is the blurb from the Watford Valves website...
    "There are the original small bottle American Military JAN 6L6WGB/5881 that was made for the USA Military in the mid 1980S. These are Full Jan Specification which means that they are long life and superbly made with the highest grade materials. No modern day 6L6GC valve is made to this specification
    These are the ultimate 6L6 type for use in any Fender amplifier but paticularly the Fender bassmans as no other valves gives a 59 bassman the early breakup and that rich midrange twang as this classic.The bass response is big and tight with a smooth warmth. It provides all the classic Fender sounds with ease. Solo and riffs are punchy and fat It also does not get muddy and fizzy under extreme satuaration. So it is equally at home in modern high gain amplifiers.
    This is why this one of my all time favourites and the one that I have used in my own amps for many years.
    I have run these myself in a series of Silveface Fender Twins, Mesa Boogie MK 4,Boogie 400 plus and Fender bassmans including Silverface 100 head.
    The specification of these valves are also different from the Early Tung-sol and R.C.A 6L6WGB valves as these can supply 30 watts plate dissipation without any problems and can run with 6l6GC anode voltages."
    So maybe safe to bias up to 30w / 424v x 0.7 = 49ma ?
  15. MajorNut1967
    Jul 30, 2009
    3,883
    338
    HMM! Sounds like a bunch of HooYa why don't we stick with the original 6L6WGB SPEC. to be safe! try it at 44mA.
    http://www.mif.pg.gda.pl/homepages/frank/sheets/087/6/6L6WGB.pdf
  16. musicman
    Nov 9, 2009
    784
    95
    Will give it a go tomorrow.
    Thanks for your advice.
  17. demonufo
    demonufo New Member
    Oct 23, 2010
    2,211
    258
    defunctprofilesville
    I guess these must be tubes that were made in the Sylvania plant then?
    Quite a lot of "different" tubes coming out of there in the 80's.
  18. musicman
    Nov 9, 2009
    784
    95
    Reset the bias to 44ma - well 44 on one tube 41 on the other - the pair is not particularly well matched & the difference follows the tube.
    Sounds better but I'm not blown away.
    Think I'll try some KT66's at some point but I wouldn't spend £72 on a pair of JAN Philips again.
    Thanks for everyone's help and advice.
  19. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Well mate, I wish he would've gone with the KT66 power tubes in the first place! If the 5881 power tubes were a few milliamps off spec wise you could ask to return them and get credit towards the purchase of some KT66’s? Anyway the KT 66 will give you a nice clean tone similar to what a 6L6/5881 would, but when pushed hard they break up really nice and would give you that old classic Marshall sound. With that being said I can't believe they charged you 72 quid for a pair of 5881 tubes.
  20. musicman
    Nov 9, 2009
    784
    95
    The amp has a sticker on the chassis saying replace with 5881 valves only.
    Don't get me wrong I like the amp, I just prefer the Sovtek valves.
    Whatever you pay in $ we pay in £ so the JAN Philips are £30 each plus 20% VAT (Value Added Tax) - what a rip off.
