JTM45 reissue with EL34's ????
Discussion in 'Marshall Amps' started by alwayssomthing, Apr 2, 2011.
  1. alwayssomthing
    alwayssomthing New Member
    Apr 2, 2011
    5
    I have a 1989 JTM45 reissue that has Groove Tube EL34's and a solid state rectifier. Bought this amp in a pawn shop so no info is available. Looking on the web I found that they come stock with 5881's and a tube rectifier...
    I've had no issues with this amp and it is the best sounding tube amp I've ever played (I've had Carvin and Peavey tube amps for the last 20 years)
    Just wandering if anyone has a JTM45 RI with EL34's and a solid state (plug in) rectifier and did you have to do any mods to accommodate the EL34's.
    After playing this amp for the last week, I've falling in love with it and want to try to find more info on it and if it has had mod's done to it.
    Any input would be greatly appreciated
    Thanks
  2. ItsChrispyTv
    ItsChrispyTv New Member
    May 15, 2010
    604
    80
    Live in the south.....of the uk
    well 5881 and EL34's have been known to be mixed before e.g. 6100 series some have 34's others had 5881's. My advice is, if you like the tone then who cares? The chances are it was just a factory thing marshall did. Marshall had a tendancy to change tube types when stocks got low (800 series some had 6550's others had EL34's) At the end of the day. Yes it could have been modded, but if you like it so much then it was modded for the greater good.
    My advice.
    If it ain;t broke, don't fix it!
  3. Lespaulnmarshall
    Lespaulnmarshall Well-Known Member
    Aug 31, 2009
    5,533
    891
    The JTM45's originally had KT66's. But in the late 80's they started running out of 34's and they decided to re-design it as a 5881 amp. In the mid 90's they started making them with el34's and later they went back to 5881's. I have a 5881 model, but I'm running KT66's in it now, and it's amazing!
  4. Birk
    Birk New Member
    Mar 20, 2009
    75
    Norway
    My '89 JTM45RI had 5881 tubes in it, now it has KT-66.
  5. seoohyes
    seoohyes New Member
    Apr 4, 2011
    :lol: i argree with you
  6. bodhi2600
    bodhi2600 New Member
    Apr 12, 2010
    173
    59
    historically, the first marshall jtm45 amps used 5881 tubes. when the 5881 became scarce, the kt66 tubes were used.
    :hippie:
