JTM45. Please help me figure out the year….
Discussion in 'Let's Talk Vintage' started by hotrodtikigod, Nov 30, 2021.
  1. hotrodtikigod
    hotrodtikigod Member
    Jan 31, 2010
    43
    42
    victoria bc canada
    I was given this amp about 12 years ago. It had a blown PT when I got it. The tech I took it to suggested the MM power transformer. I’ve since learned there are better replacements. It’s been my number one gigging amp for more than 10 years. I could never figure out the year tho. I wonder if it is supposed to have a tube rectifier? I know it looks like it’s been messed with a bit. Everyone was so helpful with my SuperLead, Can someone tell me what I have here?
    lespaul339, C-Man and nickfox like this.
  2. fitz288
    fitz288 Well-Known Yinzer Gold Supporting Member
    Apr 7, 2020
    4,154
    10,658
    the Burgh
    Close up pic of the serial # might have the info you want.
    PelliX, nickfox and Dogs of Doom like this.
  3. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    Here is the serial..
    nickfox likes this.
  4. tomsvintage
    tomsvintage Well-Known Member
    Jun 11, 2012
    849
    854
    JTM45 Headquarters
    Not an expert but I would guess around 66 ish ~ chassis has the block ends that were common during that year :) Not too sure about the circuit
    Dogs of Doom likes this.
  5. South Park
    3,838
    3,580
    That silver can at the end is the rectifier . It is not a tube I Sean this on old hifi stuff . It looks like it had a tube rectifier at one time . If the wiring is still thar you can put both of them back . Nice amp
  6. Dogs of Doom
    26,419
    35,152
    can you post a better pic of this?
  7. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    Here you go…
  8. Dblgun
    Dblgun Well-Known Member
    Jan 6, 2019
    344
    587
    AZ
    Looks like a 67 tremolo with a lot going on
  9. Humbucking
    Humbucking New Member
    Jan 11, 2016
    9
  10. neikeel
    6,624
    5,682
    Yes, probably very early 67 as that OT was introduced in Feb 67 and only used in short run. Normally these were JTM50 with EL34s but I think that they used up the MKIV front panels up (same way my similar era 45/100 had EL34s and block end chassis)
    tomsvintage likes this.
  11. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    Ahh, so this is a 50 watt amp. Not 30. That explains a lot, thank you.
  12. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    So, is it proper to call this amp a JTM50? or a JTM45?
  13. neikeel
    6,624
    5,682
    It is a JTM50T with a JTM45 faceplate from the factory so I guess it is up to you what you call it, probably transition JTM45 Trem?
  14. Ricky Toney
    Ricky Toney New Member
    Aug 27, 2021
    17
    Looks like an octal socket second from the corner with diodes. The rectifier tube have been bypass with solid state rectification. You can put a switch and wire to use tube rect or solid state.
  15. dro
    dro Well-Known Member
    Aug 1, 2015
    1,309
    2,318
    Blue Springs Mo
    Yes it came with tube rectifier. GZ34
    Likely came with KT66 power tubes
  16. DeafLeopard1996
    DeafLeopard1996 New Member
    Jan 7, 2022
    Wow, what a lovely amp! That's an interesting quandary regarding the tube rectification. Doesn't look like kt66s anymore, was it possibly modded to behave more like a black flag?
  17. AndyD
    AndyD Well-Known Member
    Sep 13, 2018
    525
    558
    UK
    What a gift!!! Worth putting a Marstran transformer in it. Great project if you want it to be. Love the colour of the plexi panels.
  18. Luvverly Joobly
    Luvverly Joobly Active Member
    Apr 18, 2010
    389
    190
    West Mids, U.K
  19. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    Given to me by the best singer I have ever payed with. He picked it up in the early 70’s, but switched to lead vocal exclusively by the mid 70’s. I’ve played in a band with him for nearly 15 years. Oh…. And he was also my father in law for a time. Long story—brief marriage.
  20. hotrodtikigod
    Jan 31, 2010
    43
    42
    victoria bc canada
    I do have the original PT for it somewhere. I thought about getting it rewound, but I have other amps that need attention and are more of a priority as this amp sounds just fine with the replacement power transformer.
    Fernieite likes this.
