Jmp /jcm 800
Discussion in 'Marshall Amps' started by RLC, Apr 4, 2021.
  1. RLC
    RLC New Member
    Apr 22, 2012
    19
    21
    Are they the same? Are combo and heads the same?
  2. Matthews Guitars
    3,939
    5,980
    Generally yes. There are SOME differences depending on which model(s) you're referring to, but usually it's the same circuit in the chassis, but the chassis itself changed. The full width faceplate of the JCM800 series is, for some models, the largest change to the amp that was made. A 1959 is a 1959 whether it's a JMP or a JCM800.
    As always, the one consistent thing about Marshalls is that they were never consistent for very long. They always changed something sooner or later.
    As an example, your 2203 or 2204 kept the same general circuit UNTIL the JCM800 version was changed to horizontal rather than vertical input jacks.
  3. RLC
    RLC New Member
    Apr 22, 2012
    19
    21
    Is there a notable difference in tone between vertical and horizontal inputs?
  4. Matthews Guitars
    3,939
    5,980
    I can't attest to that myself. I'll leave that to someone who can.
  5. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,455
    2,260
    Don’t forget that some JCM800’s have a single input jack with channel switching and diodes for extra distortion.
    WellBurnTheSky and scozz like this.
  6. scozz
    Jul 20, 2008
    4,777
    10,992
    I did not know that.
  7. scozz
    Jul 20, 2008
    4,777
    10,992
    I've heard others say there is a difference, and that the vertical input JCM800s are slightly more sought after by those in the know.
    But I've never heard anyone articulate the actual differences.
  8. Trelwheen
    Trelwheen Certified B.S. Launcher Double Platinum Supporting Member
    Nov 18, 2017
    2,772
    6,237
    Texas
    I think the main difference between the vertical and horizontal input versions is that on the vertical ver. the input jacks, pots and tubes are chassis mounted with flying leads to the PCB. On the horizontal models the input jacks, pots and tubes are PCB mounted.
  9. AndyD
    AndyD Well-Known Member
    Sep 13, 2018
    328
    295
    UK
    This is a significant difference in my opinion. I would always go for the early amps ......ie jmp 2204 or vertical input Jcm800.
  10. Chrome
    Chrome Firebird Freak Gold Supporting Member
    Aug 29, 2017
    485
    818
    greeneville Tennessee
    I own a '76 JMP 1987 and a '78 JMP 2204. both 50 watt heads. In this specific example there are differences. the 76 being a NMV and the 2204 being a MV with a cascaded pre-amp. I can get break up quicker at lower volumes on the 78 than I can the 76. tone wise, they are very similar to a point. the 2204 in my opinion is the better of the two simply because I can get both with it. if I dime the master and control volume with the pre-amp I get very plexi like tones, If I dime the pre-amp and control volume with the master, I get very JCM 800 tones. it's just a matter of personal preference.
  11. Chris-in-LA
    Jul 19, 2018
    2,455
    2,260
    The vertical input 100 watt 2203 heads usually have more filter caps than horizontal input models. I haven’t played any of the earlier ones so I can’t tell you what more filtering does.
    scozz likes this.
  12. AndyD
    Sep 13, 2018
    328
    295
    UK
    I totally agree. I often quote how versatile the 2204 is. I am still discovering the secrets of this amp. If I find that it really can do everything that my NMV amp can do, them the latter may have to go. They are that good, in my opinion.
    To answer the OPs question, the amps are exactly the same in a combo as in a head. At least that’s true for the early JMP and JCMs.
    Chrome, RLC and Mitchell Pearrow like this.
  13. JP2036
    JP2036 Well-Known Member
    Aug 7, 2020
    566
    695
    No not all the same.
  14. RLC
    RLC New Member
    Apr 22, 2012
    19
    21
    Seems to me that the JCM 800 are more sought after.
  15. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,205
    2,236
    What people need to realise is it’s hard to find two jcm 800 / jmp mv’s that sound the same period , let alone difference’s between vertical and horizontal inputs .
  16. Saxon
    Saxon Member
    Jan 21, 2012
    21
    25
    Northern California
    2204's did not change, even when the horizontal inputs came along. 2203's had a filter cap change, first from 6 to 5 caps (1984) then to 3 (1985?). 2205/2210 changed late in the 80's.
    As Ufoscorpion says, even the same amps from the same time period sound different.
  17. AndyD
    Sep 13, 2018
    328
    295
    UK
    Though I can’t disagree with what you have said, I think we are opening a can of worms here. In general terms, the JMPs sound a bit different to JCMs....yes. “Are combos and heads the same?”......in general yes because the heads were designed to go in either a combo or head. Obviously sonically they are going to sound different because a combo is open backed and a head can go on anything.
  18. LPMarshall hack
    Nov 18, 2009
    11,255
    11,777
    San Diego, CA
    Significant in sound? How so (not questioning you, genuinely curious...)?
    Seems to me one may be easier to work on, but not sure if/how it could affect sound/tone.
  19. Travis398
    Travis398 Well-Known Member
    Dec 7, 2011
    1,308
    1,842
    USA
    I think they changed some of the components through the years even if the circuit stayed the same.
    Probably makes a little difference, I think the earliest ones had mustard caps.
    LargeBoxSmallBox likes this.
  20. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    1,458
    1,690
    Dave Friedman said that JMP's had better transformers than JCM800's ,
    I have a 2204 1979 JMP and a 1985 JCM800 , the JMP has a sweeter tone
    maybe because there is less plate voltage , some had high V and some had low iirc.
    When my tech made a mistake and fried the OT in my 1985 JCM , I found a 1978 JMP OT and when installed ,
    the amp had more low end bark with the JMP OT compared with the previous one.
