JCM800 4010 - EL34's or 6550's ??
Discussion in 'Marshall Amps' started by CQJR007, Aug 24, 2019.
  1. CQJR007
    CQJR007 Member
    Aug 30, 2014
    79
    45
    Huntingdon
    Which do you prefer and why ??
    Thanks guys..
  2. plexilespaul
    plexilespaul Well-Known Member
    Dec 16, 2010
    2,456
    1,133
    EL34 has more of a midrange that goes hand in hand with a jcm 800 tone.
    El Gringo and Jethro Rocker like this.
  3. CQJR007
    CQJR007 Member
    Aug 30, 2014
    79
    45
    Huntingdon
    What is the difference with the 6550's ??
    Thanks Plexilespaul
  4. Musicmaniac
    Musicmaniac Well-Known Member
    Apr 10, 2013
    311
    423
    I don't know what i prefer since I've never tried the 6550's. But I will say EL34's sound like what I grew up listening to in my 4010.
    CQJR007 likes this.
  5. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    460
    775
    6550s have a more balanced sound and are tight across the board. They don't have the EL34 compression until way up on the master volume.
  6. CQJR007
    CQJR007 Member
    Aug 30, 2014
    79
    45
    Huntingdon
    Ok, so if i want early breakup i should stay with the EL34's ??
  7. plexilespaul
    Dec 16, 2010
    2,456
    1,133
    yep
    El Gringo likes this.
  8. anitoli
    10,480
    15,431
    They are different tube designs. 6550 is a beam tetrode and an EL34 is a pentode, totally different build.
  9. CoyotesGator
    CoyotesGator Well-Known Member
    Jul 31, 2012
    2,184
    2,259
    The Institute for the Very, Very, Very Nervous
    A healthy 4010 should have platy of mids with a G12-65.
    6550’s in mine originally. KT88’s for the last 5 or so years.
    I’m somewhat of an anomaly as I use the low input and master up for crunch 90% of the time and use an open back 2X12 with CV clones in parallel with the G12-65.
    Or E34L.
    MarshallDog and Jethro Rocker like this.
  10. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    1,627
    1,963
    I was told last week by my tech that real great sounding 6550's are long gone and the nos ones you see for sale are rejects from the 90's .
    So forget about it like the Mafia says!!
  11. Brett336
    Brett336 Member
    Jan 26, 2018
    56
    88
    I have two 4010 combos. I converted one to EL-34. Both have vintage G12-65 speakers in them. The EL-34 amp seems to have a more musical power tube break up when you push them hard enough to get the power tubes to break up. But it is insanely loud at that point - unusable for me these days.
    My 6550 combo actually gets turned on more often because I think the 6550 tubes in the small combo actually make it sound bigger than it is. Much fuller in the bottom end than the EL-34 amp and the cleans are much better.
    I would say that neither is better or worse, just both different in good ways. I have vintage GE 6550 tubes - so that probably sways my opinion of the 6550 amp. I generally don't like the way that a 6550 breaks up but the original GE tubes don't sound bad to me.
    MarshallDog likes this.
  12. Trapland
    Trapland Punk, classic, funk, jazz and everything else.
    Dec 5, 2013
    1,389
    1,299
    Minneapolis
    I’ve had a few 4010s. One wth EL34s, one 6550s one started as 6550s and I converted to el34.
    If I was going to play at lower levels and use pedals for gain, I’d stay with 6550s. If I was going to crank up into powertube distortion, the EL34s are king...smoother warmer sweeter distortion. The 6550 distortion is grainier and rather solid state sounding to my ears.
    El34 all the way for me.
  13. mickeydg5
    mickeydg5 Well-Known Member
    26,789
    13,978
    united States of America
    If someone likes the EL34 sound then why not try the KT77 or even KT88 types?
    6550 are going to coinside with the 7581 and 6L6GC types.
  14. OU812
    OU812 Active Member
    Jan 14, 2012
    195
    37
    Tampa, FL
    I have a 4010 with 6550s and have owned one with 34s. Unless you get the power tubes cooking there really is no difference in my opinion. Zakk’s Marshall sounds pretty good to me.
  15. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    314
    356
    What brands of KT88 do you like and why?
  16. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    16,985
    20,851
    Taintville
    I agree 100% with you!
  17. MarshallDog
    Nov 28, 2010
    16,985
    20,851
    Taintville
    I have a 4010 with 6550s. All my other amps are EL34s except the Astoria. I was gonna convert this amp over to EL34s but after playing it for sometime now, no way, it sounds amazing sounds big like @Brett336 comments above. I am using Tung-Sol 6550s and they sound the best out of EH, JJs and Sovtek IMO!
  18. CQJR007
    CQJR007 Member
    Aug 30, 2014
    79
    45
    Huntingdon
    Decided to stay with the 34's, just came back from the tech, sounds amazing..
    Mine is a vertical input model, you guys often use the High input on this amp, i was told way back to use it sparingly, is that so ??
    Thanks again :jam:
  19. anitoli
    10,480
    15,431
    Use it as much as you want.
    CQJR007 likes this.
