JCM800 2210 effects loop quiet
Discussion in 'Marshall Amps' started by Tango, Apr 23, 2011.
  1. Tango
    Tango New Member
    Apr 18, 2011
    32
    UK
    First gig with my 2210 last night and we ended up having to bypass the effects loop and run the pedals in-front of the amp because it just wasn't loud enough to cope with gig volume. Turning the MV any further than 3 had no effect on increasing the volume. I need to use the loop, the pedals sound excellent through it but I need it loud!
    Any suggestions would be most appreciated :)
  2. Fretboard
    Fretboard New Member
    Apr 23, 2011
    115
    So when you put your pedals in through the amp's effects loop, there is a volume drop? If that's the case, try adding a volume booster, such as a Micro Amp pedal, into your loop.
  3. SigurdTheGreat
    SigurdTheGreat New Member
    Jan 7, 2010
    184
    15
    Discoville, Land of Ice and Snow
    If I remember correctly, 2210's efx loop's designed to work with rackmount units. That'd explain the experienced loss of volume.
  4. Tango
    Tango New Member
    Apr 18, 2011
    32
    UK
    Yep, there's a considerable loss of volume. Thanks for the suggestion of putting a vol booster in the loop, I had read that was a way to go but was wondering if it was possible to 'fix' it so it was possible to get normal 800 levels without a boost.
    Thank you too Siguard, much appreciated :)
  5. Fretboard
    Apr 23, 2011
    115
    Ironically, the same problem happened with a TSL on another thread. Hope the booster help.
  6. Tango
    Tango New Member
    Apr 18, 2011
    32
    UK
    Thanks, looking at the MXR micro amp for the job.
  7. soundfox
    soundfox New Member
    Jan 8, 2012
    10
    El Paso, Texas
    By any chance would anyone have a follow up to this?
    I'm experiencing the same problem and I'm considering trying the MXR.
    Does it affect tone negatively?
  8. Billie68
    Billie68 New Member
    Dec 20, 2011
    106
    25
    Charlotte, N.C.
    I had a problem sort of like that with a different amp manufacturer, I ran a few pedals In the loop & volume dropped when the pedal was In the loop not even on or In operating mode, took the pedal out, & cured the problem, I asked around & the best answer I recieved was that pedal was probably manufactured with a different Impedance. I had to go 1 by 1 with the pedals to find the one It was.
