JCM2000 TSL 100 sounds going out
Discussion in 'The Workbench' started by kharvelan, Jan 22, 2009.
  1. kharvelan
    kharvelan New Member
    Aug 22, 2008
    88
    columbus ohio
    I'm just posting to verify.
    When playing my marshall it sometimes just goes very quiet in volume. It will then kick back into normal volume later. I'm thinking it's a bad preamp tube, I did notice that one tube is not getting as warm as the others when it goes quiet.
    Would the best bet just be to swap out one preamp tube and just try it out and see if that does it, or is there other stuff that can cause it to drop in volume randomly?
  2. Onza_Jk
    Onza_Jk New Member
    Jan 21, 2009
    50
    Volume drops, are due to faulty and dieing tubes. I would try replacing it and see if it fix's it.
  3. kharvelan
    Aug 22, 2008
    88
    columbus ohio
    yep that was it, I bought a tube and just swapped it out and kept trying til I found the bad one.
    just thought I'd post an update.
    too bad it was my overdrive tube (the only JJ in the bunch) so I will have to order a batch of tung sols this weekend, but at least its working and not dying out.
