JustGaryLee
- Joined
- May 10, 2022
- Messages
- 12
- Reaction score
- 24
Hey fellow rockers, I am using a JCM 900, i run my modulation pedals through the effects loop. I used to use a JCM 2000 TSL an it had a pedal board that allowed me to "BYPASS" my effects loop. My 900 doesnt have that set up. Is there a pedal or switch i can add into the line to bypass what im using on my effects loop? I know there are pedals that you can buy to add pedals to that pedal to controll them...i simply want to use my effect loop on my amp and be able to bypass it. Any help appreciated just please dont respond as a gear snob about diode clipping or buy another amp...the diode clipping has been modified, buying another amp at this point is out of the question. Thank you in advance.
