Jcm 900 4100 Loop
Discussion in 'Marshall Amps' started by Pixim, Aug 8, 2018.
  1. Pixim
    Pixim New Member
    Nov 21, 2013
    13
    Montréal, Canada
    Hi folks!
    I'm looking to set the Loop level for using with a Boss GT-10 (4 cable method).
    Do I need to set the loop at High or Low on the JCM? I'm not sure if HIGH = +4dBu and LOW = -10dBV...
    Thank you !
  2. anitoli
    8,455
    10,719
    Use whatever sounds best.
  3. Pixim
    Pixim New Member
    Nov 21, 2013
    13
    Montréal, Canada
    Boss says to use the -10bBV on the Amp loop. This is why I ask...
  4. anitoli
    8,455
    10,719
    Sure they may recommend that but you may find with some devices the sound will be better the other way, or if you have more than one pedal in the loop line you may need to make a compromise to get them all to work in a satisfactory manner. It doesn't hurt anything to try it both ways.
    Pixim likes this.
  5. Pixim
    Pixim New Member
    Nov 21, 2013
    13
    Montréal, Canada
    Ok... I will do my own tests !
  6. Marshall4Metal
    Marshall4Metal Well-Known Member
    Jul 28, 2016
    383
    462
    Start with the loop level at noon and work from there.
