JCM 800 vs Kemper Profiler
Discussion in 'Marshall Amps' started by GuitarIV, Mar 9, 2021.
  1. saxon68
    saxon68 Well-Known Member
    Mar 15, 2013
    2,297
    2,687
    West Virginia
    I had helix and was tweaking too much, went to Kemper and purchased a few profiles (maybe 50-75 bucks total?) and I don’t tweak anymore.
    Ni6htWalker and Maggot Brain like this.
  2. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    2,219
    4,093
    NH
    Tweaking isn’t a hardware issue tho—I had an AXE dove in real deep but now I have a Helix and pretty much run stock amps through Celestion IRs...diminishing returns
  3. tallcoolone
    Mar 7, 2011
    2,219
    4,093
    NH
    But fantastic that you found something that works for you!
  4. Frodebro
    Frodebro Well-Known Member
    May 14, 2014
    4,844
    6,711
    Seattle
    It's all in your monitoring system. Using the cab that is baked into the profile will give you the sound of the cab and the mic used to capture the profile. Running a studio profile through studio or PA monitors is going to yield way different results than running a direct profile through a traditional cab.
    giblesp and Maggot Brain like this.
  5. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    No offense man (seriously, no offense), but those QSC power amps were among the worst I tested with my Axe FX. Class "B" amps are known for producing nasty crossover distortion. If that's what your using to amplify the Kemper, and it's working for you, that's great, but I'd suggest trying some Class "A/B" amps to get the most from your Kemper.
  6. Frodebro
    May 14, 2014
    4,844
    6,711
    Seattle
    I use the QSC only once in a while when I run in stereo, my KPA has the internal amp. Also, I rarely run the 4x12s these days since buying a Kemper Kab.
  7. giblesp
    giblesp Well-Known Member
    May 3, 2015
    477
    540
    So what the Kemper is profiling is the miked 800. So the profile is going to be as good as the mike placement. That requires some technique.
    What the Kemper is actually played through, is also a factor just as what cab you use for your 800 is a factor. And don't forget, you are hearing a profile of a miked amp with the Kemper, whereas you are playing through an actual amp/cab in the room.
    The real test would be when you mike your amp, both go through the soundboard and then you compare the results. Or, plug into an interface to record. It may then sound very close.
    I own a JVM, but can't mike it due to where I live. The Kemper is a great recording tool for those who need to record at low levels. If I could mike my amp though, I probably would.
    Some swear by using an FRFR cabinet with their Kemper, I've never tried and don't need to as my Marshall will not be replaced for live use. But some users are happy to take a Kemper along to a gig and use an FRFR on stage, or plug straight into the soundboard. Mark Knopfler is currently doing this.
    When I A/B my Kemper and Marshall, the Kemper sounds like a miked amp going through monitors and the Marshall sounds like an amp in the room. I've tweaked the hell out of it though, over a period of years.
    Michael Roe and Maggot Brain like this.
  8. Guitarpete
    Guitarpete New Member
    Oct 6, 2015
    in my experience you are going to have a hell of a time keeping up with a decent tube amp - especially so once it warms up and is cranked up enough to breath properly. Don't get me wrong, I am a hardcore IT guy. However, would we have Hendrix if there was only digital? A warm amp and glowing tubes...
  9. Ni6htWalker
    Ni6htWalker New Member
    Dec 25, 2020
    5
    4
    im just going to leave this...
    Frodebro and Dogs of Doom like this.
  10. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    I don't think anyone with any sense would dispute that a Kemper or Fractal can produce excellent recording results, as good as a real tube amp (IMO). I think the topic most often debated is whether they can compete with real tube amps, regarding "amp in the room" tone and feel (through a guitar cab). In my experience, this can also be achieved (at least, with a Fractal), but is much more challenging.
  11. saxon68
    Mar 15, 2013
    2,297
    2,687
    West Virginia
    The key words there are cranked up.
    Hendrix lived and played in a time when you could take a Marshall and crank it, your typical musician doesn’t have that luxury now.
    proper tool for the proper job/application, hence why I’ve got a Kemper AND a JVM half stack.
  12. giblesp
    May 3, 2015
    477
    540
    True, but we wouldn't all be able to record the way we do at home, without digital. In fact, who's using all analog now anyway? Even if you are miking an amp, you'll be going into a computer. Maybe Jimi in 2021 would still be using his amps. But he'd be recording into a computer.
    I can still remember 4 track days and going down to studio to make a demo. Now I can make very good sounding demos at home.
    Tube is a gold standard, but digital has changed my musical world in so many ways for the better.
    tallcoolone likes this.
  13. tallcoolone
    Mar 7, 2011
    2,219
    4,093
    NH
    Hendrix would be the first one experimenting with this stuff.
    Frodebro and Maggot Brain like this.
  14. tallcoolone
    Mar 7, 2011
    2,219
    4,093
    NH
    Yup. But really this only matters to home hobbyists. Experienced live players are used to hearing themselves through stage monitors (mic'd sound) and experienced recording artists are used to cans (mic'd sound).
  15. marshallmellowed
    Jun 26, 2009
    5,025
    7,866
    Not just important to "home hobbyists" (IMO). I play live gigs regularly, and while I am used to hearing myself through monitors, I still enjoy playing through tube amps at home, it's a different experience. I'll take amp through a cab over over mic'd/direct amp through a monitor any day. :)
  16. tallcoolone
    Mar 7, 2011
    2,219
    4,093
    NH
    That right there is why I am standing in front of 8 tube amps my man! I do not live in 'either/or land'! Nothing scratches every itch
  17. Ni6htWalker
    Dec 25, 2020
    5
    4
    and with the Kemper too,
  18. TKB
    TKB Member
    Sep 22, 2016
    53
    38
    Minnesota (summer) Florida (winter)
    I've had a few Marshalls including the 2203 and I've loved them all BUT...I do believe psychology plays a heavy role in this conversation. I have told musicians in the past that simple things like room humidity can change air density and speaker flexibility to make a killer sound one day be so-so the next. Not many believed me. I know tube purists that don't believe tube sounding tones are possible from anything solid state but I disagree. You should of had a neutral party listen to the A/B test or posted them for opinions. A musician on Soundcloud called Jeff Fiorentino nails EVH's first album sound with a GFX 212 Crate tranny amp (listen to his song "Air is for pussies" to hear what I'm talking about). I've seen those amps for $40 and Eddie had a real Marshall. I would have liked your friends opinion on the test. Belief is a powerful thing my Friend. I have seen many musicians using the Kemper and I thought it nailed the Marshall sound,,,and I own a Marshall. I'm just sayin............
  19. Dogs of Doom
    25,768
    33,120
    just hunted that down, sounds more like Jake E Lee in Ozzy meets George Lynch in Dokken...
    TKB likes this.
  20. Whizzercone
    Whizzercone Member
    Feb 3, 2021
    20
    28
    Profiling an amp and cab and expecting it to sound like the amp isn't going to work out well.
    TKB likes this.
