Jcm 800 4210 presence resistor?
Discussion in 'The Workbench' started by Tyon sceen, Nov 25, 2020.
  1. Tyon sceen
    Tyon sceen New Member
    Nov 25, 2020
    5
    I’ve done a ton of reading, but can find any good pictures online of the resistor to remove to set the presence at 0. From what I’ve read, there’s a fixed resistor instead of a presence pot on these amps. This amp is really bright! I would like to remove the resistor to try and take out the brightness. Can anyone point out the resistor to snip to get rid of the fixed presence. I think this is a January 1983 amp. Thanks.
  2. Tyon sceen
    Nov 25, 2020
    5
    Here’s some pictures
  3. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,306
    2,056
    Las Vegas, NV
    @Tyon sceen
    First, :welcome: to this great forum!
    Next, blue arrows below indicate the connections of the "Presence/Negative Feedback Loop" to the Phase Inverter and 4Ω tap of the Output Transformer. Though I do not believe that simply removing the resistor to either eliminate the loop or putting a jumper in its place it is the wisest solution here! Changing the value of that resistor or replacing it with a variable one may be more appropriate. Folks with more expert experience will likely chime in here soon to help!
    And you may also find that modding an amp by a "paint by numbers/point to which component" approach (without full understanding of what is actually going on) may be a sad and/or dangerous path to follow.
    Just My :2c:,
    Gene
    Dogs of Doom and thetragichero like this.
  4. thetragichero
    Jun 6, 2010
    2,911
    948
    flo rida
    if it's too bright try removing the 220pf bright cap from the volume pot (reducing the value would only allow higher highs through and might be nice too)
    also keep in mind that unlike a standard tmb tone stack this James tone stack is boost/cut so it is x neutral" with both knobs at noon. i wouldn't see it being bright with treble control at zero
    South Park likes this.
  5. Tyon sceen
    Nov 25, 2020
    5
  6. parachute
    parachute Member
    Jul 23, 2015
    44
    42
    Is it the bright cap from the volume pot, or the gain pot? Because I had a bright cap removed from the gain pot on mine by a tech (thats what he told me, the gain pot) , and it did help to lower the brightness.
  7. parachute
    parachute Member
    Jul 23, 2015
    44
    42
    And i did have a presence control pot placed at the back of the amp earlier, but that doesn't really help as much, at least at bedroom levels.
  8. thetragichero
    Jun 6, 2010
    2,911
    948
    flo rida
    schematic up there shows a stock presence control. i wouldn't have a 50w amp for bedroom levels anyway but yes since it is negative feedback from the output transformer its effectiveness is based on the output level
    normal channel or boost channel too bright? they each have a bright cap on the volume controls
  9. Gene Ballzz
    Feb 19, 2013
    2,306
    2,056
    Las Vegas, NV
    That's a bit odd, considering its the exact amp as initially described, with the dates being in the correct range.
    Hmmm, Very Interesting!
    Gene
  10. Tyon sceen
    Nov 25, 2020
    5
    Stock control is on the 2205, 4210 has fixed resistor instead of pot.
  11. South Park
    3,314
    2,821
    You should look at the tone cap that presence resister is hooked up to . That is what is rolling off frequency’s . Just a idea
  12. Tyon sceen
    Nov 25, 2020
    5
    I decided to put a pillow in front of the speaker. Read a lot today about people putting blankets over their speaker cabs. The pillow definitely tamed the brightness! Can turn the volume up higher. Great solution for now. This amp sounds great now. What about a speaker change? Thoughts?
