JCM 800 2203x or SC20
Discussion in 'Marshall Amps' started by Frehley12, May 25, 2020.
  1. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    I have an itch for a JCM 800. Local sale for a used 2203x for $1200 excellent condition. I don't play out. I have been focused on the SC20 head until this 2203x popped up for sale. I would be running either through my SJ 4x12 with v30s.
    I also have an empty SJ 2555X head shell. Would a 2203x chassis fit a 2555x head shell box?
    Mitchell Pearrow and 67mike like this.
  2. 67mike
    67mike Well-Known Member
    Mar 5, 2015
    633
    585
    I would buy that 2203x and yes...will fit into the 2555x shell
    dptone5, Trelwheen, Kelia and 2 others like this.
  3. Lance Chambers
    Jun 23, 2019
    1,487
    2,296
    The Land That Time Forgot
    You should buy the SC20 for home use, so I can buy the 2203X for home use. :fever:
    tce63, Trelwheen, houseofrock and 3 others like this.
  4. marshallmellowed
    Jun 26, 2009
    3,747
    4,540
    It depends on if you're buying for what you "want", or what you "need". That's a good price or a 2203x, but unless you're playing outdoors, with no PA, it would be overkill (IMO). The master volume needs to be at around 2.5-3 for the amp to sound it's best, and that's very loud indoors.
  5. LPMarshall hack
    Nov 18, 2009
    10,771
    9,958
    San Diego, CA
    I say get the 2203x. It’ll have a ton more girth than the SC. Although I imagine the SC would sound pretty beefy thru a 4x12.
    I’m no help.
  6. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    What's the volume taper on the SC20?
  7. marshallmellowed
    Jun 26, 2009
    3,747
    4,540
    It's the same as the 2203x, the amp starts to come alive at around 2.5-3.
  8. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    So on 2 the SC is LOUD as F@@k? Does one have a "better" loop than the other?
  9. 67mike
    Mar 5, 2015
    633
    585
    The real 2203 will eat and crap out the mini one for breakfast.
    R.H, FogDweller, Kelia and 3 others like this.
  10. houseofrock
    houseofrock Well-Known Member
    Jul 10, 2015
    876
    969
    Florida
    2203x
    but what do I know I have 2 superbasses for home use.
  11. JBA
    JBA Well-Known Member
    Nov 14, 2016
    318
    357
    2203 unless weight is an issue for you; that is the only “unless” I can think of ;-)
    Lance Chambers likes this.
  12. Filipe Soares
    Mar 8, 2019
    1,263
    2,053
    2203 and an attenuator.
  13. marshallmellowed
    Jun 26, 2009
    3,747
    4,540
    I'm guessing you haven't played through both a SC20 or 2203x on 2? The SC20 on 2 is not loud, compared to a 2203x on 2.
  14. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    I played on a used 2203x many years ago at a GC and don't remember where the volume was set. Just low enough not to piss off the employees. I should have bought it as it was THAT sound I so crave.
    I have played on a SC20 for literally a minute or 2 back in December. The settings on it sounded great as soon as I plugged in and turned it on. Don't remember where the volume was set. It wasn't loud.
    So where on the SC20's volume compares to 2 on the 2203x?
  15. Frehley12
    Frehley12 Member
    May 3, 2015
    49
    39
    I received the following on the 2203x after contacting the seller:
    "The only two things were done with the amp. I replaced all the filter capacitors with new F&T capacitors. Also, these amps come equipped with two board mounted potentiometers. One is for adjusting the bias, and the other is for adjusting PT hum. The original pots was professionally replaced with a single resistor. This is common practice for the 2203X as those pots usually fail. There is tons of data about this issue on the net. Check it out. The rest of the amp is totally original. The F&T caps are of way better quality then the crappy Chinese ones Marshall put in there. Do a bit of research on the caps as well. F&Ts are the best available today. All the boutique amp makers use them."
    How does that sound to you guys? I understand the filter cap job but the pots on bias and PT hum I'm not familiar with. Hot air or a good thing?
    dptone5 likes this.
  16. marshallmellowed
    Jun 26, 2009
    3,747
    4,540
    I've read of some issues with hum balance pots, but never had any issues with my amps. I've never had an issue with a bias pot, and prefer it for ease of biasing. Nothing wrong with a fixed resistor, just requires more effort to bias.
  17. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    2,042
    3,650
    Texas
    Can you play loud at home? Do you like loud?
    If so, get the 2203.
    If not, get the 2203 anyway.
    :headbanger:
    Medronio, Guitar Rod, K2JLX and 5 others like this.
  18. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    338
    507
    I'd get the 2203X for 1200 and here's why. That's as low as that price will ever go and you'll always be able to get your money back if you ever need to.
    dlang, Maggot Brain, Mystic38 and 3 others like this.
  19. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    753
    1,640
    WA state hinterlands
    Sounds like a Marshall 'humdinger pot' there have been some spectacular failures on the Marshall Astoria, here's one. A resistor will be fine but you should ask about hum because the humdinger is the bandaid fix for hum and that's gone now.
    As for the bias pot I don't like that they replaced the pot with a fixed resistor that's going to be a pain when swapping tubes. And how many times can you solder different resistors there before the PCB solder pads give out. Better to install a quality bias pot.
    See this pot, that's a 25k PEC locking pot. Only requires a 1/4 inch hole. I use these for bias pots and stick them out the top of the chassis so I don't have to pull the chassis from the head shell to bias. Loosen the nut, bias the tubes, tighten the nut to lock the pot.
  20. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    542
    435
    I have a 2203X and it's very loud. But it does have a nice pure tone. And that's a good price for a used one.
    junk notes likes this.
