JCM 800 2203 MK2 6550 bias question
Discussion in 'The Workbench' started by BobVigo, Mar 7, 2021.
  1. BobVigo
    BobVigo Member
    Sep 4, 2020
    35
    9
    I picked this up and from my understanding, the MK2 came with 6550?
    are there bias points in this circuit to take the readings?
    If not, pins 1&8 are tied together, can I put a 1ohm between them and ground for the cathode bias method?
  2. South Park
    3,480
    3,000
    In order to take a bias reading you have to measure grid current . That means you have cut the circuit and go through a amp meter . You get a bias probe and put a amp meter in between it and read how many mili amps the grid is using . If the amp is working sounding good then what is the need .
  3. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    2,215
    1,976
    Yes.
  4. neikeel
    5,606
    4,103
    As above
    Don’t try to bias as 30w tubes, if you go to 70%. Treat them as 25w tubes, ie 17.5w at idle.
  5. pedecamp
    16,393
    14,949
    Watch and learn:
