dannylerch
- Joined
- Jul 29, 2012
- Messages
- 40
- Reaction score
- 14
Hey guys,
I recently upgraded my 4x12 cabinet to x2 WGS British leads and X2 WGS retro 30s.
I wired them in parallel 8 ohm fashion because I only have two lead connectors on my cab(I have a vintage style cab). A friend said I could wire them the same as my old 8 ohm speakers. These new ones are 16 ohms. I had my speaker cable coming out of my 16ohm jack from the head. Should I of had it in the 8ohm jack?
My speakers are wired like that^^^
After looking at another diagram, is looks like I should have had a second jumper.
Could this be my problem?
Well the amp sounded great for two practices til tonight. I was playing at a volume of around 7oclock, and my volume started dropping and my tone started breaking up. I immediately shut off the amp, took off the back plate, and turned the amp back on. My tubes are all lit up, I noticed a little blue in my first power tube. But they are getting power. Noticed just a slight electrical burn smell when i put my face in the back of the amp, but nothing too crazy.
Basically I'm trying to see if I overloaded my tubes with the speaker load, did I blow something else like a transformer, resistor, etc?
