JCM 2000 DSL 201 once more, with FEELING...
Discussion in 'The Workbench' started by DOCPAGE, Jun 11, 2020.
  1. DOCPAGE
    DOCPAGE Member
    Sep 11, 2019
    36
    30
    Hi everyone; I’ve posted many times about this amp, made in 1998, Mercury Magnetics OPT; I’m just a few keystrokes away from calling it a piece of S**T and selling it for parts...
    NOW, after replacing the bridge rectifier (thanks to the input from this forum), and it working fairly well, I’ll be playing anywhere from 20 minutes to 2 hours, and intermittently it just STOPS. It’s like a ghost reached around the back and pulled the plug out. Just stops. Pilot light goes out. The end. Then, sometimes after 5 or 6 minutes, it just as suddenly comes back on. Sometimes it DOESN’T come back on at all, but the next day it will. Fuse problems maybe? Any advice, besides selling it for parts (which I’m about to do)? Thanks, as always...
    Chris
  2. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,264
    2,266
    Wilton NSW
    The pilot light runs right off the mains input before the power transformer, so if that is going out then there must be some very simple problem in the mains wiring or power switch
    thetragichero likes this.
  3. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,908
    1,642
    Is there any way you can get inside when it shuts down and check some voltages?
  4. ricksdisconnected
    Aug 11, 2019
    4,258
    6,437
    dont sell it just take it to a quality repair guy.
  5. tmingle
    tmingle Well-Known Member
    Jan 24, 2008
    361
    341
    Mifflintown, Pa.
    IIRC, my DSL401 had a bunch of really crappy push on connectors for the wires to the switches, xformers etc. I would check those as well as the power switch itself. I would also check the actual crimp connections on the push on terminals. Between guitar amps & the equipment I maintain for a living, I have literally fixed over 100 of these stupid things that were not crimped correctly.
  6. DOCPAGE
    DOCPAGE Member
    Sep 11, 2019
    36
    30
    Well, I have a guy, he replaced the bridge rectifier, but he says the circuit boards are really fragile, he’s not sure how many times it can be taken out....maybe I find a new guy....
    ricksdisconnected likes this.
  7. ricksdisconnected
    Aug 11, 2019
    4,258
    6,437
    yes, find a new guy. FAST
  8. DOCPAGE
    DOCPAGE Member
    Sep 11, 2019
    36
    30
    Lol
