Isolated Power Supplies for pedal boards
Discussion in 'The Workbench' started by mad5066, Feb 28, 2021.
  1. mad5066
    mad5066 Well-Known Member
    Jan 16, 2010
    268
    383
    I'm seeing a lot more companies throw their hat in the ring making "isolated" power supplies for pedals. Seeing the physical dimensions, I'm having a hard time believing that they are truly isolated power supplies since I doubt it has a toroidal inside unless they've gotten much much smaller. Having a regulator per tap does not making it truly isolated in my mind as they still share the same ground, like some MXR stuff and cheaper joyo. You need a single transformer tap per dedicated isolated line. Unless they've come up with a new way of doing this that I don't know about allowing it to be a smaller form factor? But stil,l even if it was several dedicated switching supplies, one per line, that still isn't truly isolated in terms of how I'm considering it. Could that be how Cioks, or fender's new line is doing?
    SkyMonkey likes this.
  2. mad5066
    Jan 16, 2010
    268
    383
    Ok, CIOKS actually is isolated and I guess they had custom transformers wound that are much thinner in profile. I have the truetone isolated one and the custom audio one that are physically larger.
  3. thetragichero
    Jun 6, 2010
    3,230
    1,169
    flo rida
    i use an old laptop (19vdc) wall wart through a 12v and then a 10v linear regulator (giving me 9.81v like a nice fresh battery) and a daisy chain. works fine for me in my board made from a scrap of 3/4" ply
  4. ricksdisconnected
    Aug 11, 2019
    5,801
    8,886
    :photos:
  5. thetragichero
    Jun 6, 2010
    3,230
    1,169
    flo rida
    ain't pretty but it works
    SkyMonkey and ricksdisconnected like this.
  6. SkyMonkey
    3,255
    4,310
    I recently decided to get a PSU solution for my 8-pedal, 'play at home' pedalboard.
    A 1700mA daisy chain worked silently for all but one pedal, a Boss RC-3.
    The Cioks range were some of those I considered, but one of my pedals draws 500mA, so even the DC10 is out (400mA max).
    In the end I've gone for an Ammoon Isolated Power Supply that uses a 12V 2A 'Wall Wort' to supply an isolated 9V splitter box under the board.
    https://www.amazon.co.uk/gp/product/B07JNDWQRN/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    This was on a recommendation from a member of another musician forum.
    It'll be getting here from China (I think) in a couple of weeks, so I post my impression when it comes.
    But at less than a third the cost of the DC10 (in the UK), I had to give it a shot.
    Admittedly, I have blown some of the savings on a set of 'better' and 'shorter' Rockboard adapters than the bulky 60cm ones that it's supplied with, but I suspect the Cioks comes with 'far too long' adapters too.
    Also, having the actual transformer 'off-board' means the EMF cannot interfere with the signal path.
    This guy proves the 'Isolation' of his purchase at 3:20.
  7. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,562
    2,353
    Las Vegas, NV
    I personally like the concept of a rechargeable battery pack power supply. It frees you from the need to run an AC power cable alongside or near your signal cables! Several years ago, I bought a BoxKing and it's been great for my use. Unfortunately, this brand seems no longer available and is a little "cheesy" in some ways, but still a fantastic concept. While the outputs are not isolated from each other, the isolation from AC is a huge improvement. I get 10 to 12 hours of fairly heavy use on a full charge and if it gets low (from forgetting to charge it) it operates on it's wall wart. Some guy on one of the forums I frequent designed and built his own and I've been trying to find it, but have had no luck! I'm surpeised there are not more offerings of this type! It certainly fixes a lot of issues!
    https://www.amazon.com/gp/product/B074FWK46G/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    Just Sayin'
    Gene
  8. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    2,217
    2,301
    Lots of great things can happen with regulated pedal power. You can actually change the affect of the effect and give it a different characteristic, nuance or artifact with voltage..
  9. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,702
    1,237
    UK
    I agree - a lot of the cheaper so-called isolated PSUs are nothing of the sort! A giveaway is usually the light weight! Often these units will have separate 9V outputs - but the 0v will be common to all the output sockets!
    I bought such a cheap "MOOER" unit. it was terrible! with a high-gain amp like my JVM, clean power (with no ground loops) is essential!
    I ended up with two VOODOO LAB units. These are not cheap, but they are the best. They have a torroidal transformer, and true-isolated outputs!........
    mad5066 likes this.
  10. mad5066
    Jan 16, 2010
    268
    383
    Yep, what annoys me is a lot of companies marketing claims isolated when I know for a fact they aren't. Best way to really confirm is with gut shots of the circuitry.
    spacerocker likes this.
  11. TXOldRedRocker
    TXOldRedRocker Senior Discount Member Gold Supporting Member
    May 15, 2020
    747
    1,919
    Cypress, TX
    mad5066 likes this.
  12. adew1
    adew1 Active Member
    Jul 18, 2020
    225
    153
    Switzerland
    Which ones?
  13. BatmansMarshall
    May 15, 2020
    275
    362
    Lives in the mid-range.
    Yeah you have to research before you buy. Some units are just daisy chains in a box. The price reflects that also.
  14. mad5066
    Jan 16, 2010
    268
    383
    Usually anything under $100 bucks. Donner, joyo, etc.
  15. snark
    snark Active Member
    Feb 19, 2011
    142
    91
    I've been using these expert series power supplies for a couple of years and they are very good....
    https://yankee.com.pl/
