Is it legal to use Tube Screamer with Silver Jubilee
Discussion in 'Marshall Amps' started by arayadis, Nov 30, 2021.
  1. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    3,601
    4,280
    Shakedown Street
    I will chime in and say it is not needed at all . As why would you need it to begin with and you are so correct that I do run my pair wide open as that is truly the best way to get the sonic joys and wonders of the glorious tone . Clean wise this can peel paint and then go to the lead channel and buckle in buck a roo as it is where the fun is for myself :headbanger:
  2. PelliX
    PelliX Well-Known Member
    Jun 16, 2020
    1,599
    2,982
    SRV was one heck of a criminal, though.
    Indeed. I've thought about spraying a 1U rack case green and putting the guts of the TS in there. Keep the footswitch in the original pedal (might want it just to control a relay inside the rack kit or something, though). "TS9-R1".
  3. gregr
    gregr Well-Known Member
    Jul 30, 2014
    766
    851
    True, but seeing as though he’s dead…
    :io:
    PelliX likes this.
  4. PelliX
    Jun 16, 2020
    1,599
    2,982
    Buddy Guy is still going... :)
  5. Eric'45
    Eric'45 Well-Known Member
    Oct 2, 2021
    326
    849
    Germany
    I'd say it's not illegal, but doesn't make sense.
    In fact, No Overdrive Pedal ever made sense in front of a Tube Amp...
    If you have a Tube Amp- use it's Tube Distortion. If you have a Tube Amp that has not enough Gain on Tap for your desired Sound, use another one, that has.
    Why use a OD as a clean boost if a EQ Pedal gives you more flexibility or a Treble Booster naturally just boosts the right frequencies...
    I have tried to like Transistor based OD Pedals in every possible configuration, but I never have found one that worked for me.
    Rudy v and GregM like this.
  6. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    1,481
    2,695
    Not in Europe no. Where are you based?
    Actually I used to use a tubescreamer on all the time with my tsl. Clean boost only as mentioned above. Worked pretty well I thought.
  7. Neptical
    Neptical Well-Known Member
    Jun 13, 2010
    588
    1,379
    Transylvania
    Illegal.
    It's called the SD-1.
    :pirate:
  8. gregr
    Jul 30, 2014
    766
    851
    The ‘80s called. They want their SD-1 back.
  9. Jethro Rocker
    10,259
    15,791
    I have used an OD in front of mine mainly as an extra bit of grind in Lead channel. I use the pedal with Level UP and NO gain so pedal is simply boosting a hotter signal to front end. I have found TS etc with simply a tone control to thin things oit a bit so I use OD with a 2 or 3 band EQ control.
    Nothung wrong with it at all, if you want extra thick meaty metal tones, do whatever ya like with it.
  10. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    1,403
    2,456
    Iowa
    If it isn't broke then don't fix it!
  11. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,654
    The SD-1 sounds killer on the Jubilee. I also like the ZW44 which i think may just be a SD clone.
  12. gregr
    Jul 30, 2014
    766
    851
    Oh it’s broken.
    …as I’ve alienated 85% of the forum.
    scozz and GregM like this.
  13. gregr
    Jul 30, 2014
    766
    851
    Metal tones: Horizon Devices Precision Drive.
    But who plays metal through a Jubilee?
  14. AlvisX
    AlvisX Garage Guerrilla Gold Supporting Member
    May 31, 2011
    5,976
    13,891
    I-55 Corridor
    Im pretty sure Audley was using a TS with the Jube in his Cry Of Love days
  15. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,654
    I do and so did Gary Holt with Slayer.
  16. gregr
    Jul 30, 2014
    766
    851
    Pure amp or with an overdrive and if with an overdrive which one?
  17. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    2,493
    2,766
    Had a mint 1988 ( black ) 2554 for a while , which was the most frustrating amp I’ve ever owned . The Jubilee range of amps are held in such high esteem but as much as I tried , couldn’t get a decent sound out of it . Really dull and lifeless , the best I could get out of it was set clean with my mxr 5150 od for dirt .
    Tatzmann likes this.
  18. gregr
    Jul 30, 2014
    766
    851
    EMGs
    Ufoscorpion likes this.
  19. JacksonCharvelAddict
    Mar 4, 2016
    2,214
    2,654
    I think the lead channel works fine for metal on it's own but for tight thrash rhythm parts I use a slight clean boost. I use several boosts with it. Keeley modded Ds1. Zw44 and tube screamer.
  20. Jethro Rocker
    10,259
    15,791
    Depending what metal. I do old school amd hair metal with mine.
