Id Marshall JMP
Discussion in 'Let's Talk Vintage' started by rafalynch, Nov 21, 2020.
  1. rafalynch
    rafalynch Active Member
    Sep 4, 2014
    246
    132
    Hello, I am sold this amplifier online and I only have these photos, the serial number is very rare when starting with the letter V would be from 1987 .. and the 4 speaker outputs, someone knows what model it can be and what year and approximate value? thank you
  2. rafalynch
    Sep 4, 2014
    246
    132
    [url = https: //ibb.co/k8fTHMV] [​IMG]
  3. rafalynch
    Sep 4, 2014
    246
    132
  4. rafalynch
    Sep 4, 2014
    246
    132
  5. Valvelust
    Valvelust Well-Known Member
    Feb 9, 2010
    513
    256
    In the midst of trees
    Yes it is interesting...
    Year 1987 (Canadian version) EL34's?
    Polarity switch?
    Appears to be a model 1959
    Value? Low $1200 High $2000
    rafalynch likes this.
  6. rafalynch
    Sep 4, 2014
    246
    132
    Thank you very much .... I found it very strange to have never seen one like it.
  7. neikeel
    4,864
    3,258
    I think that it is a 1959S model (please check tho'!) these were made late 80's - often in black/green levant head cabs. The rounded front panel corners on the head cab were quite distinctive.
    Marshallhead and rafalynch like this.
  8. Valvelust
    Feb 9, 2010
    513
    256
    "S" would represent small in a small head and cab and the back would have a bunch of different writing, disclosers etc, maybe even a barcode.
    Also a sticker would indicate that on the top of the chassis.
    tce63, rafalynch and Drinkingdeath01 like this.
  9. Drinkingdeath01
    Drinkingdeath01 Well-Known Member Gold Supporting Member
    Feb 1, 2010
    1,120
    2,674
    Minneapolis Minnesota
    I have the 2204S but I've never seen a 1959S before. Now I will spend the next few years searching for one. Thanks Neikeel, thanks a lot. Lol.
  10. Matthews Guitars
    2,777
    4,121
    Four inputs and four speaker outputs and six knobs makes it a 1959. That the back panel includes "MARK II" on it means 1974 or later. "Super Lead 100w" also is definitively for a 1959. That it has the coin type impedance selector means it's made not before 1979. That it's a 1987 production amp means it's a 1959 reissue, which specific version I don't know.
    Valvelust and rafalynch like this.
  11. Valvelust
    Feb 9, 2010
    513
    256
    I've never known a reissue to have that plain back panel without all the disclaimers and other writing...however I could be wrong.:shrug:
  12. Matthews Guitars
    2,777
    4,121
    That kind of puzzles me, too. Looks like a regular '70s back panel. I guess we'd have to get a look inside the chassis.
    I've seen that the extra warning labels are waterslide decals that were applied after the panels were made. They can be removed without a lot of effort,
    and with the right solvent, any additional printing or silk screening could be removed as well, leaving no trace on the panel. That'd make it look more vintage correct.
    So, what 1980s era 1959 reissues would there have been?
  13. StuC
    StuC Member
    35
    33
    As neikeel said, it's 1959S. They all had a polarity switch and four speaker jacks. There was also a 1987S.
    The early 1959SLP, 1987X and JTM45 reissues also had the rounded control panel cutouts.
  14. metromutt
    metromutt Well-Known Member
    Jul 15, 2009
    709
    296
    England
    From the Doyles History of Marshall book... Although the picture shows the 1959S
    Valvelust likes this.
  15. Valvelust
    Feb 9, 2010
    513
    256
    Looks like a good explanation to me. I didn't know they had done that. Like to see back panel of the advertised one and inside of the OP's. I don't see a polarity switch though but may have been on the 1959S ?
  16. metromutt
    Jul 15, 2009
    709
    296
    England
    All UK/Europe marshall's don't have the polarity switch and only feature two speaker jacks on the back.
    The 50 watt S's were in small headboxes but could be recognised by the large corner curves cut out for the control panel.
  17. neikeel
    4,864
    3,258
