How will this sound and feel ?
Discussion in 'The Workbench' started by Hebaton, Jul 8, 2021.
  1. Hebaton
    Hebaton Active Member
    Nov 4, 2011
    271
    41
    I am looking at Traynor YBA-1 variations and one version has 1K5/125uf on V1A and V1B
    How would this change behaviour as opposed to plexi values ( currently in there )
  2. Hebaton
    Nov 4, 2011
    271
    41
    will no one please me here ?
    those are cathode bypass values of course
    thanks
  3. thetragichero
    Jun 6, 2010
    3,321
    1,271
    flo rida
    Pete Farrington likes this.
  4. thetragichero
    Jun 6, 2010
    3,321
    1,271
    flo rida
    also sometimes you have to wait more than four hours for a reply
    next time maybe do some googling and see if you can't find out for yourself in the interim?
  5. Hebaton
    Nov 4, 2011
    271
    41
    Thank you, and thank you for taming my inpatience somewhat.
    I did search but, I guess I'm not so good at it. Waht I found did not seem very clear to me.
    That asaid, AM-I to stand 1K5 wothout bypass cap in frequesnt in fenders ? Is tha what you are saying ?
  6. Pete Farrington
    Jan 18, 2021
    572
    556
    I understand this calculator to be more accurate, it’s a nice user interface and uses the gold standard formula from RDH4
    http://bmamps.com/CapCal.html
    No, Fender typically use a 25 or 22uF bypass cap.
    PelliX and Stephen H like this.
  7. Hebaton
    Nov 4, 2011
    271
    41
    reverted to original values. May do the same to tone stack.
    I have decided to make this just the best clean amp possible.
    any clues towards that goal would be appreciated. I originally asked a tech to make it as close as possible to a JTM45 but that never really worked so her I am.
    curently driving KT66 power tubes. should I stay with those o go back to EL34 type ?
  8. Stephen H
    Stephen H Member
    Jun 21, 2021
    39
    33
    Nimbin
    I would stick with the kt66's, bit more clean headroom... maybe (I'm no expert in anything, just a monkey.)
  9. Pete Farrington
    Jan 18, 2021
    572
    556
    Depending on how you define 'clean headroom', that seems more like probably not to me.
    They probably won't reach overdrive until the vol control is turned higher. But that's due to the power stage almost certainly having a somewhat lower gain with them.
    I think most versions of YBA-1 are intended for EL34 / 6CA7 with their OT having a primary impedance around 3k4, so that valve type should put out more power into that than KT66 are likely to.
    But beam pentodes (KT66, 6L6) can sound and respond a bit differently to suppressor grid pentodes (EL34), so try both and go with your preference.
    Personally, when I tried a YBA-1 with both EL34 and 6L6GC (all Winged C), at band sound levels, the amp seemed punchier and 'bigger' with 6L6GC, even though on the bench, the clean power outputs with either were about the same.
    The owner wanted to use it as a clean pedal platform, so stuck with 6L6GC.
    Stephen H and tallcoolone like this.
  10. thetragichero
    Jun 6, 2010
    3,321
    1,271
    flo rida
    i've switched both yba-1 and yba-1a to 6550s (adjustable bias, lowered bias feed resistor values) with good results. especially the yba-1a which uses two 6ca7 for a quoted 80 or 90 watts. runs em hot enough that it came with a fan. maybe okay with the mullards that came in it but i would imagine murder on modern production tubes!
