Clayton Custom Cabs
I have two CRATE amps V32 Palomino and V3112 I have schematics for both and have recapped, re-resistered and re-tubed them. They actually sound quite good now, the issue is harsh and splashy reverb.
It appears to me that both use IC's for drive, am I reading that correctly? In any event I removed the TL072 on the VC3112 and soldered in a socket. Then I installed the NE5332 chip that the schematic shows. It's less noisy, but still splashy and harsh. The tanks are rusted funky on both amps.
Here is my question for guru's! How do I find the input/output impedances of the reverb circuit so that I buy the correct tank?
Thanks as always!
BTW - I asked the same ? on TGP if you follow it too.
Thanks as always!
