HELP with Marshall "Echohead" delay pedal
Discussion in 'The Tone Zone' started by Tom Rossiter, Nov 28, 2020.
  1. Tom Rossiter
    Tom Rossiter New Member
    Oct 24, 2020
    6
    7
    Here is my sad story. Two weeks ago I purchased from Ebay a Marshall Echohead delay pedal for $85. The pedal looked to be in new condition with box and manual. When I received the pedal it worked great and I loved the sound and clean delay. The other day the pedal started to get noisy when you turn up the "Level" control. The noise is a sporadic white crackling noise that is low level in the background and also on the secondary decay end of the notes or chords.
    I really like this pedal and hope it can be repaired. Has anyone else experienced this problem with the Echohead pedals? Is there a place in the USA that would be able to repair the Marshall pedals for a reasonable fee?
    Thanks.
  2. Bluemoon78
    Bluemoon78 Active Member
    Jan 20, 2007
    215
    51
    Manchester, UK
    Are you using a battery or mains? Delays can sounds like this with a low battery.
    El Gringo likes this.
  3. Tom Rossiter
    Oct 24, 2020
    6
    7
    The battery was brand new....and only used in the delay for about 1 hour. Its possible its the battery, I can try a new one and see. I do need to find a 9v adapter.
    Thanks
  4. Tom Rossiter
    Oct 24, 2020
    6
    7
    Bluemoon78, thank you so much, it was the battery! It was at 8volts. Maybe these delay is a power hog since this battery only lasted 2 hrs. The pedal does have 2 circuit boards.
    El Gringo and Bluemoon78 like this.
