Help setting up pedals and effects loop….
El Gringo
Shakedown Street
That sounds weird. I have an original 2558 and a mini Jubilee. I use loop for multi fx now but used to use for delay, reverb and flanger. Clean loop no problems at all.
What are you running yhrough the loop specifically?
Only got fx thru loop meanjng.... no dry signal at all?
Nothing in the loop as everything is up front . With the Radial Engineering Big Shot ABY pedal and both 2555X's going thru that I tried running the pedals ( Cry Baby , Phase 90, BOSS tuner, Boss Flanger, BOSS Chorus, and BOSS Delay )(the only pedals I ever use ) thru the one 2555X loop and the pedals only came thru that 2555X . So I then went back to going thru the front as I always have . It was more of a curiosity for going thru the loop . To answer the last question the 2555X that was not used for the loop was only the dry signal , which I thought was odd as both amps were going thru the Big Shot ABY pedal , which is why I figured the loop effects would go thru both amps due to the Big Shot being used .
El Gringo
Shakedown Street
Deleted as I posted in the wrong thread which I corrected and posted in the Dimarzio double white pickup thread .
