Have you ever blown a Celestion G12T-75w speaker?
EADGBE
If so, with what amp? And with how many watts was the amp? And what were the circumstances?
Neptical
Across the World
Yes.
Mesa Single Rectifier.
50 watts.
Cranked outdoors for a set.
Amp was RUMBLIN' those speakers! As we know, the dispersement of sound outdoors on a BIG stage gets weird. It's my old JCM 800 1960 cab. I'm chalking it up to the years of abuse before the contribution of Rectifier.
EADGBE
Yes.
50 watts.
Wow. I didn't think that was possible. A 50 watt amp blowing a 300 watt cab's speaker.
RCM 800
it might take a long time but speakers are a wear item, just like anything with moving parts. That being said the only speakers I ever blew were in an ADA cab being pushed hard by a Mesa Single rec. Im not sure what the rating was on them but they were repaced by a pair of t75's and a pair of V30's I picked up used and never had a problem again.
mark123
Yes.
I had a crate 1x12 cab with the G12T. I blew it out with my 1972 Super Bass.
Matthews Guitars
Just remember, amp power ratings are based on clean, undistorted power stage output. But a cranked 100 watt Marshall 1959 Superlead is factory specified to put out 170 watts at 10 percent distortion. (About half that for a 50 watter.)
Once distortion is in the picture, the energy level increases rapidly.
I've heard that a particularly healthy plexi can deliver up to 220 watts equivalent power.
This is why some people don't recommend that a 4x12 full of 25 watt Greenbacks should be run for a long time with a cranked Superlead. It's recommended that if you're going to do that, you use two cabinets.
Deftone
Auburn, CA
I had the cone lock up on one in a 2x12 Avatar. Amp was a Joyo Zombie 20w hybrid.
geddy
Yes but it wasn't the amp. It was the pressure wave from the pyro about 2 feet behind it. Tore both speaker cones out. Luckily Celestion didn't charge much to re-cone them
