Has anyone modded this pedal?
Discussion in 'Marshall Amps' started by RachelMorgan, May 9, 2008.
  1. RachelMorgan
    RachelMorgan New Member
    May 5, 2008
    241
    10
    Seattle
    The Vintage Modern pedal has two switches. One for gain level and the other for reverb. I really wish they had put some LEDs on there so you could see where you are, especially with the reverb. The gain is pretty obvious if you're in the wrong one, but still it would be nice to have a LED there, too.
    How difficult would this be to do? I know I'd have to drill a couple holes.
  2. Brett Blackmore
    Brett Blackmore New Member
    Apr 16, 2008
    481
    47
    Bingen, Germany
    Hi,
    Easy, and cheap too. You need to find out what the voltage is. Lets say it is 12v. You know need to find out what the voltage the LED works at. Lets say 4v. So you need a resistor rated at the difference in voltage so the LED does not get too much v. In this case it would be 8v. Drop them in parallel to the on/off circuit and off you go!
    Please note: I have NO idea what the voltage is so do check that out first!
    Cheers Brett
  3. mikemoss
    mikemoss New Member
    May 9, 2008
    4
    Born in Long island NY, now living in Greece
    i believe that with time you ll always have the reverb on so it wont be an issue. However if you combine the magnificent VM with some midi controllable devices (say TC gsystem or whatever effect or even preamp etc...) then also get a bigger footswitch with leds and display of preset so you know if reverb is on...
  4. coldsteal2
    coldsteal2 Well-Known Member
    Sep 22, 2007
    1,903
    107
    Chico, CA
    The only real reason you would need a light
    is for the reverb
