Guidance re 4 inputs
Discussion in 'Other Amps' started by Wailing, Jan 24, 2021.
  1. Wailing
    Wailing Active Member
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
    A2572819-5AA8-4C19-861C-BEF9C4FA0985.jpeg Hi Folks... Could anyone give me a steer with regard to what the 4 inputs do on my Nolan amp please ?
    mirrorman and tce63 like this.
  2. Travis398
    Travis398 Well-Known Member
    Dec 7, 2011
    1,160
    1,592
    USA
    Looks like you have a Hi and Low input for each channel. You may need to plug in to verify, but I would guess the left two jacks is for volume 1 and the right 2 jacks is for volume 2. Top jacks are probably hi input bottom low input.
    One channel is probably more highs and the other channel more lows and of course you can put a jumper cable between the channels so you can run both volumes and have the best of both worlds.
    Wailing likes this.
  3. scozz
    Jul 20, 2008
    4,393
    9,958
    Looks like it’s a Plexi takeoff.
    WellBurnTheSky, tce63 and Wailing like this.
  4. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
    Thanks for the responses, how would I run a ‘jumper cable’ ? and how would it affect the tone ?
  5. pedecamp
    16,194
    14,579
    Buddy do you have a patch cable, youre gonna have to just try it and see what you like. Typically plug guitar into top left input, patch cable into bottom left input, other end of patch cable into top right input, dial up both volumes to a mix you like. I typically do this with single coil guitars to fatten the tone, with humbucker guitars I dont jumper the channels at all and just plug into the top left input and leave the other channel off.
    tce63 and Travis398 like this.
  6. Travis398
    Dec 7, 2011
    1,160
    1,592
    USA
    Pedecamp is right just take a regular patch cable or a short fancy one like this
    WellBurnTheSky, tce63 and pedecamp like this.
  7. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    2,456
    2,225
    Las Vegas, NV
    Few folks actually understand the complex interactions of the standard Fender/Marshall 2-channel/4-jack input arrangement. Below is a link to a detailed description of the whole setup, including what can be expected from each different jumpering configuration along with the actual impedances derived from Rob doing all the math!
    And FWIW, I'd love to know more about that very rare and highly regarded "Nolan" amplifier!
    Just Jumpin'
    Gene
    https://robrobinette.com/How_Fender_Input_Jacks_Work.htm
  8. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
    Cheers folks... great source of knowledge.. will post some pictures ASAP
    tce63 likes this.
  9. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
  10. scozz
    Jul 20, 2008
    4,393
    9,958
  11. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
    Which of the Marshall or Fender amps does this amp resemble?
  12. Gene Ballzz
    Feb 19, 2013
    2,456
    2,225
    Las Vegas, NV
    WOW! Even though that's a printed circuit board, the traces look mighty robust! NOICE! And while there appear to be multiple taps on the output transformer, there is no simple means of selecting them?
    Odd?
    Gene
    ibmorjamn and tce63 like this.
  13. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,202
    2,148
    Printed? Looks etched
    WellBurnTheSky likes this.
  14. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
    I think you are correct Adieu, I think the chap who serviced it for me said the board was etched, I am guessing etching the board is a more laborious process than printed boards. Unfortunately I do not have the technological knowledge to respond to the output transformer question. The amp can produce thick clean tones and then moves to a mid toned crunch with ease. Any other thoughts on which model it resembles?
  15. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    1,044
    1,711
    Canada
    When I first saw the pic, I immediately thought of a Hiwatt DR-504 with the controls, inputs and switches backwards.
  16. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    8,342
    6,628
    North
  17. ibmorjamn
    Nov 3, 2012
    8,342
    6,628
    North
    You could get a ohm meter and check to see what inputs have , not powered , plug in cable and check each set of inputs.
  18. ibmorjamn
    Nov 3, 2012
    8,342
    6,628
    North
    Wailing likes this.
  19. Wailing
    Nov 24, 2015
    120
    70
    Cambridgeshire UK
  20. ibmorjamn
    Nov 3, 2012
    8,342
    6,628
    North
    I have not seen a schematic but the plexi’s were closely derived from the fender’s.
    Wailing likes this.
