Good generic amp for music venue?
Discussion in 'Other Amps' started by EuanH91, Nov 30, 2020.
  1. mantrasky
    mantrasky Well-Known Member
    Apr 18, 2013
    274
    407
    California
    Thank You! (I need to practice) "Keep on Rockin" \../
    solarburnDSL50 likes this.
  2. solarburnDSL50
    Aug 8, 2008
    17,618
    13,809
    Wetville
    Absolutely! You rawk.
  3. Kidlargo
    Kidlargo Member
    Feb 8, 2017
    20
    53
    A JVM410 full stack and you've got all you need for whatever comes though that door.
  4. Dean Swindell
    Dean Swindell Well-Known Member
    Mar 12, 2017
    287
    267
    I was going to say a Boogie Filmore 50. But if that costs too much a Fender Hotrod Deluxe. I used to use backlines all the time and ended up usually with a silver face twin which I always had to use a pedal for an overdrive generator which i HATED and still do. These are two good amps that can do a good representation of what probably anyone wants to do.
  5. Norfolk Martin
    Norfolk Martin Member
    Jan 29, 2013
    52
    33
    I assume you will be presenting a wide variety of styles, so I would be wary of amps that are primarily known for crunch or high gain. A Twin or similar amp can do a good clean Fender sound but still work well enough for hard rock with a pedal in front. If someone does need a high gain sound and is traveling without an amp, I assume they will have a suitable pedal.
  6. Phillip Whitelives
    Phillip Whitelives New Member
    Jul 9, 2020
    9
    10
    Marshall JCM 900 Dual Reverb or Mesa Rectoverb. Both have good cleans, and can get nice distortion tones.
  7. guitronics
    guitronics New Member
    Dec 19, 2010
    16
    12
    This is a dumb question, I know; but what is IR?
  8. assquatch20
    assquatch20 Active Member
    Jan 19, 2019
    86
    156
    Tennessee
    Impulse Response
  9. dro
    dro Well-Known Member
    Aug 1, 2015
    1,060
    1,862
    Blue Springs Mo
    You may want to consider that tube amps require maintenance. And if left off and unplugged foe lengths of time. Should be slowly charged to prevent shocking the caps by throwing high voltage at empty caps. If it were my money. I would be taking these things into account.
  10. FutureProf88
    FutureProf88 Well-Known Member
    Oct 2, 2012
    2,259
    1,681
    St. Louis metro area
    I'd vote either DSL half stack or (and I almost hate suggesting this) a used mini Rectifier half stack. Either of those can cover gainy tones themselves but also have good enough clean channels to be good pedal platforms.
