Good Amp Feedback (Sustain)
Discussion in 'The Tone Zone' started by Gianni, Sep 20, 2014.
  1. Gianni
    Gianni Well-Known Member
    Sep 13, 2014
    2,647
    3,676
    Greece
    Hello everyone.
    I really hope you can offer some insight into the following two questions.
    In a home-studio setting, using a JVM, 1 Watt, amp head, with your guitar facing the speakers and enough volume/overdrive, would you expect to be able to create feedback (sustain) of a single note more easily with:
    1. A 60-Watt OR a 140-Watt Cab?
    2. An open-back OR a closed-back Cab?
    Or does it not make much difference either way?
    Cheers,
    Gianni
  2. 12barjunkie
    12barjunkie Well-Known Member
    Dec 30, 2011
    2,786
    3,069
    Ft Wayne, IN
    Volume and gain are the key; speakers/cab configuration not as important.
    Gianni likes this.
  3. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,138
    U need 99 more watts ...
  4. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    CharvelDan,
    Well, I don’t have them. :D
    But I’m sure you already know that a 1-Watt valve amp through just one efficient speaker, let alone more, can get quite loud, too loud for home use when cranked up.
    Good for you if you’ve actually played in venues where you could turn up your master volume and hear what your amp really sounds like, ‘cause most people have only heard the preamp tubes of their 100-Watt amps working. Then again, if you’ve ever tried to crank up your 100-Watt amp at home, I sure hope you can still hear yourself playing your guitar.
    Although I did find your response amusing, after 3790 posts, and with all the impressive gear I see in your photos, I’m sure you can be much more helpful.
    flyingskull and Ghostman like this.
  5. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    12BarJunkie,
    Thanks a lot for the quick response and input.
    I am very sorry for your recent loss.
    I’ve just posted a message in the relevant thread.
    12barjunkie likes this.
  6. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Just to explain the reason behind my post, I was just thinking that the speakers of a 60-Watt cab could be ‘moved’ more easily than those of a 140-Watt one by a 1-Watt amp, as well as that an open-back cab, having more mids, would also help with creating feedback. I’m quite new to all this and may well be wrong.
  7. The Ozzk
    The Ozzk Well-Known Member
    Mar 28, 2011
    6,777
    7,070
    Calgary, AB
    Volume and a touch of reverb. :yesway:
    Gianni likes this.
  8. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    The Ozzk,
    Thanks a lot for your input.
    The Ozzk likes this.
  9. charveldan
    Jan 31, 2010
    8,248
    5,138
    What u can do is fret the 6th and or 5th string which is low e and a on the 5th and 7th fret while facing the cab and crank the amp to get it howling.
    Thats how alot of pros do it and when they find the sweet spot for that gig or venue they mark the floor with a piece of gaff tape so the know where to stand.
    Gianni likes this.
  10. dreyn77
    dreyn77 Well-Known Member
    Feb 18, 2012
    12,559
    2,857
    multiple silly pedals into the front of the amp.
    I got the VH eruption sound from a 5010 and the MXR 6 band EQ pedal and the phase 90 pedal. the amps volume could be set anywhere, but I had the same sound type and feedback with the amps Vol setting on '0.5'.
    Gianni likes this.
  11. dreyn77
    Feb 18, 2012
    12,559
    2,857
    I posted the settings ages ago. I think it was in the tone zone.
  12. charveldan
    Jan 31, 2010
    8,248
    5,138
  13. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    CharvelDan,
    Thank you very much for the useful info.
    I just knew you could do a lot better! ;)
    I did enjoy your YouTube videos too.
    charveldan likes this.
  14. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Dreyn77,
    Thanks a lot for the useful info.
    You’ve got too many posts, mate, but I’ll look for it.
  15. blues_n_cues
    blues_n_cues Well-Known Member VIP Member
    Jul 9, 2010
    22,226
    20,104
    Dixie Hollow
    fresh strings and maybe even a compressor for added sustain if needed.:yesway:
    cvaldeski, The Ozzk and Gianni like this.
  16. 2203xman
    2203xman Well-Known Member
    Jan 30, 2012
    3,051
    2,943
    Hillbilly Heaven USA
    Sometimes you can create some sustained feedback just by creating a 'kind of pich harmonic followed by some vibrato.Sort of the same technic that EVH uses on every note he plays by holding the pick between the thumb and middle finger.This feels a little strange at first,but can spice up your tone a bit.
    Gianni likes this.
  17. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    Blues n Cues,
    I’ve just listened to ‘Stratisfied’ in ReverbNation, and I can’t tell you how ‘stratisfying’ it was for me too!
    What a lovely piece of music; so sweet and aggressive at the same time.
    Bloody hell, mate. You’re a guitar God!
    blues_n_cues likes this.
  18. Gianni
    Sep 13, 2014
    2,647
    3,676
    Greece
    2203xman,
    Thanks a lot for your interesting, and spicy, input.
  19. ampmadscientist
    17,865
    12,058
    Science of Sustain
    is a positive feedback loop, which originates at the strings.
    The sound comes from the string, into the pickup, through the amp, out of the speaker, thru the air (as acoustic waves), which then reaches the guitar, and re-vibrates the string, starting the loop cycle over again.
    For example, if the acoustic sound reaches the guitar in-phase to the original string vibration, sustain will occur.
    If the sound reaches the string 180 degrees out-of-phase...
    cancellation occurs. Sustain is prevented.
    Then, the phase alignment of the guitar VS. acoustic wave from the speaker becomes pretty important.
    But wait, there's more...
    The wood that the guitar is made out of, can effect sustain dramatically. And completely independent of the hardware, pickups, and strings.
    I may have a rock maple Gibson L6-S, and no matter what hardware or pickups, it won't sustain. It's dead as a blanket.
    Then I take the same hardware and pickups, put it on a mahogany body, and it sustains like crazy.
    So there is a lot more to Science of sustain than just the phase alignment, strings, pickups, and electronics. More Importantly it's a function of guitar wood, construction and materials, in a vastly underrated way.
    cvaldeski and Gianni like this.
  20. dreyn77
    Feb 18, 2012
    12,559
    2,857
    I think my settings were, bass, mids, treble, and gain all 10, vol 0.5, pres, 'don't remember', mxr EQ frown boost and phase 90, slowish speed.
