As you well know I am a very proud owner of the beautiful Silver Jubilee! As a self confessed Slash Dork I’m always looking for different things to add to the authenticity of the tone. This time round I purchased a 10 band MXR EQ. Dare I say it- do I have the tone nailed!!?
Thanks so much!! Don’t get me wrong 9/10 I THINK I have it but listen back and feel like it’s weak but this time I got to say, I’m very happy with the results!
Killer! Underrated secret sauce. Phenomenal in the front or the loop. Fantastic through all my amps and only ever have to tweak the 31.25 or 16k sliders a hair. Volume and Gain is rad also. I love mine!
Wow! That’s sounds asewome, man. Thanks for sharing. Looks real identical to me. Can you record something with just your guitar?
I just upgraded my rig with an Ashly 31 band stereo EQ. One side I use for input and the other I use for loop....EQ makes an incredible difference and I cannot recommend one enough (try the 31 band if you get a chance...the bulk instrument you have with the 10 band (I had one and found that for the stuff I play it is a little off in the frequencies) turns into a scalpel to surgically alter your tone for the better.) I actually prefer the MXR 6 band apples to oranges to the 10 band (I find the frequencies seem to line up better and you get more control over range with the 6 band(10 band does 12db and the 6 band does 18db). Although oddly enough while the changes I used to make were gross with the 6 band, I have found with the 31 band I actually get by only using the 6db setting...so less change to the range of the boost or cut but a lot more precise in the frequencies I adjust.
