Formulas
Discussion in 'The Workbench' started by Apostle Tone, Dec 12, 2009.
  1. Apostle Tone
    Apostle Tone New Member
    Oct 23, 2009
    59
    Colorado
    Is there or what is the formula for figuring out how many watts an amp is putting out based on voltages? better yet is there a program/web site that will compute it for you if you put in the voltages?
    Thanks,
    Danny
  2. thrawn86
    thrawn86 Well-Known Member
    Aug 6, 2009
    6,721
    1,773
    Yes, the program is called WilderAmplification.stud and you can find it here on the forum somewhere....in fact, it will probably find this thread sooner or later.... :D
    Seriously, he probably knows.
  3. Apostle Tone
    Oct 23, 2009
    59
    Colorado
    That's why I come here and ask questions. There seems to be much knowledge here and I have much to learn.
  4. MajorNut1967
    MajorNut1967 New Member
    Jul 30, 2009
    3,883
    338
    Hey Danny,
    The basic formula for this is, "Power-in equals power out" Now if you want to know based on a specific Tube then Wilder is your man, I'm too lazy.
  5. thrawn86
    Aug 6, 2009
    6,721
    1,773
    That's why I suggested the WilderAmp.stud program. The MN1967.lame program is virus ridden. And a nancy boy. :naughty: :lol: :wave: :hmm: :lol: :)
  6. MajorNut1967
    Jul 30, 2009
    3,883
    338
    You meany:lol::lol::lol::lol:
    I think I'll go have a cry!
  7. Wilder Amplification
    Wilder Amplification New Member
    Oct 12, 2009
    6,163
    723
    Fresno, CA
    Fuckin' threadjackers n' shit. :D
    In order to calculate your power output, you'll need a scope, signal generator and a resistive dummy load. You can make one out of four 16 ohm 50 watt power resistors wired in series/parallel for a 16 ohm 200 watt load. These resistors must be mounted to some sort of a heat sink to be able to run at their rating.
    Using the scope, you would inject a 1kHz signal and turn the volume up while watching the scope. Turn the volume up until the signal is just at the onset of clipping (i.e. starting to flatten out on the top/bottom of the sine wave).
    Then you'd use a multimeter to measure the AC voltage across the load. Once you have that, you can calculate your clean power one of two ways -
    Method 1
    Power = (Voltage Squared) / Load in Ohms
    Example, you measure 40VAC across the load. Multiply 40 by itself
    40 x 40 = 1600
    Then divide 1600 by the load value -
    1600 / 16 = 100 watts
    Method 2
    Current = Voltage / Load
    Example...you measure 40VAC across the load. Divide that voltage by the load value to get the current.
    40VAC / 16 ohms = 2.5 Amps
    Now multiply the voltage by the current to get the power.
    Power = Voltage x Current
    40VAC x 2.5 Amps = 100 Watts
  8. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Isn't Wilder brilliant! He's my Zero; I mean Hero!
  9. MartyStrat54
    Feb 21, 2009
    26,014
    9,593
    Licksville
    The formula derived from Ohm's Law for Power is:
    Watts = Volts^2(squared) divided by Ohm's
    Watts = Amps^2(squared) multiplied by Ohm's
    Watts = Volts multiplied by Amps
  10. MartyStrat54
    Feb 21, 2009
    26,014
    9,593
    Licksville
    As usual, a day late and a buck short with my post.
  11. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Oh forgit Marty he's my other hero!
  12. thrawn86
    Aug 6, 2009
    6,721
    1,773
    Did you ever know that you're my Heroes? That's for all of you.
  13. MajorNut1967
    Jul 30, 2009
    3,883
    338
    AWWWWWWWWWWWWWW!
    And a "Happy Christmas" to you and your's!
    Your my Hero too, I just don't tell anyone.
  14. thrawn86
    Aug 6, 2009
    6,721
    1,773
    Yeah, let's just keep it that way.......now back away slooooowly...don't make eye contact with the Major.......now RUN
    :lol:
  15. Apostle Tone
    Oct 23, 2009
    59
    Colorado
    Wow! Ok, I don't have a scope so I guess that's out.
    I have a small combo amp that runs on either one 6L6 - I have a JJ
    or it can run with one 6V6GC - I have a Tunsol
    In my other amp I'm using two TAD 6L6wgc-str tubes
    What is a "Nancy boy?" Is that like a mamma's boy?
  16. MartyStrat54
    Feb 21, 2009
    26,014
    9,593
    Licksville
    A Nancy Boy? Well...:hmm:...to be polite, it's a young, feminine guy who wears his underwear on backwards. He is also known to take long community showers where he is constantly going for the loose bar of soap on the floor.
    Am I painting the picture good enough?
  17. Iron Mang
    Iron Mang New Member
    Dec 9, 2009
    33
    Kaleponi
    Holy shit did ya have go to that zone! Now everyone knows that MJN1967 wear his tights backwards!
  18. MartyStrat54
    Feb 21, 2009
    26,014
    9,593
    Licksville
    :io::io::io:
    :eek::p:eek2::eek2::p:eek:
  19. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Ya Ok then I won't tell then the time I caught him trying on my sisters Bra & Panties!
  20. Iron Mang
    Dec 9, 2009
    33
    Kaleponi
    LOL you bastard!:lol::lol::lol:
    Duck Rocker forever' Bro Quack Quack!
